Mileage correction - Page 3 - Mercedes-Benz Forum
post #21 of 31 (permalink) Old 04-24-2019, 04:53 PM
Date registered: Jun 2015
Vehicle: 1997 W202 C220
Quoted: 29 Post(s)
Originally Posted by boyd waugh View Post
Yes, sensible, showing the mileage to give somebody a plug and play.
This evening I have ordered from e bay a copy of my own speedo head for £19.00, mileage unknown and an eeprog programmer for £16.00.
I'll report back.
When you purchase an eeprom programmer, would it be an easy procedure to do to redo your mileage counter? Do you also need a Star diagnostic to do that or only the eeprom programmer would suffice?
jakewise is offline
post #22 of 31 (permalink) Old 04-24-2019, 05:17 PM Thread Starter
Date registered: Feb 2009
Vehicle: 1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Quoted: 85 Post(s)
Just the eeprom Jake.
Comes with a disc download.
U tube has good video to show how to do it.
I will be keeping my original intact just in case of slip ups.
Thanks to Deplore, at the start of this thread for the suggestion and I have searched for info on how to do it.
boyd waugh is offline
post #23 of 31 (permalink) Old 04-24-2019, 05:37 PM
Quoted: 29 Post(s)
https://www.youtube.com/watch?v=Ct_pps24HPA
From the looks of the video, it seems you'll have to remove the eeprom from the cluster. I guess that is where I am scared to do as there might be a problem that may arise thereafter. I was hoping just to plug it to our 38 pin diagnostic plug if there is one. But please give us a feedback if you do it. Thanks
jakewise is offline
post #24 of 31 (permalink) Old 04-24-2019, 05:45 PM Thread Starter
Quoted: 85 Post(s)
I wish it was that easy Jake.
post #25 of 31 (permalink) Old 04-24-2019, 05:47 PM
Quoted: 29 Post(s)
very true, how we all wish . .
Since you are removing the eeprom from your old cluster, will it not be better if you just replace the eeprom of the donor cluster?
jakewise is offline
post #26 of 31 (permalink) Old 04-24-2019, 06:04 PM Thread Starter
Quoted: 85 Post(s)
Donor cluster is of unknown mileage Jake, that is the problem, or it would be plug and play.
However, if the donor shows more than 194k then happy days.
post #27 of 31 (permalink) Old 04-24-2019, 07:52 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 770 Post(s)
Doesn't matter, if donor cluster is the same as your current cluster, can just swap eeprom directly.
Deplore is offline
post #28 of 31 (permalink) Old 04-24-2019, 08:38 PM
Quoted: 29 Post(s)
Deplore, when you say same donor cluster, I presume you meant same part number?
Assuming both clusters have the same part number, you can swap eeproms to get your old cluster's mileage to the donor cluster? Will that be an easy thing to do without possible damage to the donor cluster?
jakewise is offline
post #29 of 31 (permalink) Old 04-24-2019, 10:18 PM
SDS Guru
Deplore's Avatar
Quoted: 770 Post(s)
Same PCB. Same transistor, same mosfet, capacitor, MCU or what have you.
eeprom is a simple 8 legged chip. Use hot air to remove.
Look up youtube for guides.
Deplore is offline
post #30 of 31 (permalink) Old 04-25-2019, 01:14 AM
Quoted: 29 Post(s)
Thank you
jakewise is offline
Odometer and trip mileage not working 300seTexas W126 S,SE,SEC,SEL,SD,SDL Class 11 07-19-2010 01:34 PM
So what is my mileage, anyway? nopcbs W211 E-Class 19 08-03-2009 06:18 PM
Why Bad Mileage on GL320 CDI?? David Boudreau X164 GL-Class 8 05-24-2009 02:21 PM
Gas pills that give you better gas mileage!?! firstmb Off-Topic 0 04-07-2006 08:28 PM
Brake Pads, Brake/Stop Switch, ETS/BAS/ABS, and gas mileage..? AC_ML W163 M-Class 0 10-29-2002 07:27 AM
