Stuck in 1st gear - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 03-01-2019, 10:41 PM Thread Starter
Date registered: Mar 2019
Stuck in 1st gear
Hi, my 99 E320 w210 is stuck in 1st gear. Before anyone asks yes, Trans fluid level is ok. 😁 Not sure if related but was having trouble going into reverse every so often prior to this.Took her to an indie and he said need a new ESM (they think) 🙄 we can replace it but it could still be something else. Naturally I want to replace the correct part not everything else-due to 'maybes'. From what I've heard and read, issues with ESM (stuck in gear) are stuck in 3rd gear not 1st and go into limp mode. No warning lights (incl limp mode) light up -except when they're meant to before start up. Thanks for reading and hope someone can help.
Ice Queen is offline
post #2 of 23 (permalink) Old 03-01-2019, 10:45 PM Thread Starter
Oh, I am in Australia too
post #3 of 23 (permalink) Old 03-02-2019, 06:01 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 834 Post(s)
You need to get codes read from ETC and ESM. Then look in ETC live data for target gear/actual gear.
Here in US '99 E320 still had shifter with range recognition switch which is replaceable as separate part. #104.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 23 (permalink) Old 03-02-2019, 08:36 AM
Kajtek1's Avatar
Quoted: 1964 Post(s)
Sounds like SL500 I bought for $1300.
The young seller had similar feedback from transmission shops, so he sold it for pennies.
I drove 20 miles on 2nd gear home, where $10 pilot bushing, some ATF and code reset fixed it.
Good luck with the repair.
Kajtek1 is offline
post #5 of 23 (permalink) Old 03-02-2019, 09:36 AM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
The replies are trying to be helpful...
Kaj brings up a very good point - for W210's the "tranny adapter plug" at the transmission tends to internally leak over time - which mucks up communication from the tranny - and that "electrical plug" here in the US (genuine MB or MOPAR only) is like $14
This also can cause tranny fluid to "wick up" the connecting electrical cable to the Transmission Control Module" in the engine compartment - which requires pulling that circuit board and "flood" cleaning with a can of MAF cleaner (here in US like $9).
Both these items are well covered in the "stickies" at the top of the W210 forum.
Witek brings up another great point - in the shifter mechanism there is a "gear recognition switch" component that with high mileage can much up. In your '99 (and not later W210 models) that part is replaceable separately for part cost here in the Us like $120-$140 genuine MB part.
My point - with high mileage the "tranny conductor plate" can get worn - and that part genuine MB is like $180 and China made conductor plate is like $80
The point - the MercedesStar system can give you better diagnosis - BUT you need to replace adapter plug and clean TCM board FIRST to give you clean communication with your tranny THEN use Star to do diagnosis
I am NOT a fan of Australian MB owners in two areas :
(1) Australian owners tend to muck up their own cooling system/radiators by using cheap coolant and using alkaline tap water for their cooolant mix. We never need to replace radiators here in the US - in Australia radiator replacement is common for this reason
(2) Australian owners tend to not do proper ongoing tranny service - and when they do do tranny service tend to use the cheapest and incorrect transmission fluid they can find as compared to using correct MB or alternate recommended tranny fluid
Keep the beat !
fabbrisd1 is offline
post #6 of 23 (permalink) Old 03-02-2019, 09:44 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1142 Post(s)
Send a message via Skype™ to mrboca
Please clarify, whether your shifter is of PRND/321, or PRN /-D+ (touch-shift).
mrboca is online now
post #7 of 23 (permalink) Old 03-02-2019, 11:55 AM
Date registered: Feb 2015
Vehicle: 78 300CD 79 300TD 84 300SD 84 300SD#2 88 300SEL 91 560SEC 84 560SEC 95 SL600 99 E300td 99 ML320
Quoted: 11 Post(s)
Mine does that occasionally, it seems to be whatever it is reads the position of the shifter. I can jiggle it, or put it in neutral then back into D and it is fine
RichDiesel is offline
post #8 of 23 (permalink) Old 03-03-2019, 03:32 AM Thread Starter
It is a triptonic. PRND321
post #9 of 23 (permalink) Old 03-03-2019, 04:10 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 834 Post(s)
Then you don't have ESM.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 23 (permalink) Old 03-03-2019, 09:00 AM
If you have PRND-4321 arrangement, do the following.
Start the car
Turn the headlights on.
Check the gear indication lamps (LED) as you shift the selector from gear to gear. Do the light indicators reflect the correct status of the gear selected ? What does it show when the gear is in Drive ?
Occasional trouble getting the gear in Reverse may point to a loose / bad gear shifter assembly, or bad shifter bushing. If something spilled into the shifter assembly, that can cause electrical issues inside the Transmission Range Recognition Switch (TRRS).
Have a look at the video attached.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Car stuck in 1st gear! E320Wagon'02 W210 E-Class 9 09-20-2012 09:43 AM
Stuck in 1st gear cg0864 W163 M-Class 14 10-18-2010 09:15 AM
need help locating upshift delay switchover valve on 93 s600. orientalexpress W140 S-Class 11 11-23-2009 10:59 AM
Liquid in center console - car stuck in 1st gear TrishaGA General Mercedes-Benz 2 07-07-2009 08:26 PM
CLK230 Auto STUCK in 1st Gear Kai Performance General Mercedes-Benz 1 04-16-2009 10:42 PM
