2001 E-320 Station Wagon - Low Coolant Sensor - Page 2 - Mercedes-Benz Forum
post #11 of 24 (permalink) Old 05-11-2019, 03:23 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1997 E-420, 2001 E-320, 2007 S-550, 2009 E-350
Quoted: 26 Post(s)
Send a message via Yahoo to hadam
Some update. Today I got few minutes to troubleshoot the issue. I connected my Autel MaxiDiag Elite to read what is causing this message on Instrument cluster. I got message that "Short circuit on signal line to the washer fluid level/coolant level sensor" Code B112B.
Just because I did not have enough time today, so just checked the resistance on windshield washer fluid level sensor, it was only 33.6 ohms while the washer reservoir is full.
Then I measure the resistance from connector of washer fluid connector to backward, it was showing 647 ohms.
While the connector to washer fluid unplug, I went into Autel and reset the code. after that I plug it back in.
For now I am not getting message any more on instrument cluster for Coolant Low level.
One question is the washer fluid level sensor with full level in washer fluid of 33.6 ohms is good reading or bad reading? Please someone can comments on it.
Tomorrow I will try to reach to read resistance of coolant expansion tank level sensor.
Thanks in advance for your continues support.
ID:	2511890   Click image for larger version
ID:	2511892   Click image for larger version
ID:	2511894   Click image for larger version
ID:	2511896   Click image for larger version
ID:	2511900   Click image for larger version
ID:	2511902   Click image for larger version
2001 MB E-430 Gone- Totaled
2009 MB E-350
2001 MB E-320
2003 MB CLK-320 Cabriolet
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #12 of 24 (permalink) Old 05-11-2019, 04:27 PM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 216 Post(s)
What’s the tank ahead of the washer reservoir?
Sixto
98 E320 wagon
02 C320 wagon
tabijan is offline
post #13 of 24 (permalink) Old 05-11-2019, 04:27 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
Bad reading. You should get between 145 to 185 ohms at the sensor connector with the cable pulled off for a full tank.
The measurement towards the harness connector, 647 ohms is meaningless, especially if the ignition is on (it carries sense power from the cluster).
You always must make these measurements with the ignition OFF.
You may have some stray resistance on the harness to ground.
Typically you need to remove the connector at the back of the instrument cluster and make a measurement from that connector.
mrboca is online now
post #14 of 24 (permalink) Old 05-11-2019, 05:31 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 275 Post(s)
Sixto
98 E320 wagon
02 C320 wagon
Headlight washer fluid.
illstplaya is online now
post #15 of 24 (permalink) Old 05-13-2019, 10:58 AM Thread Starter
Quoted: 26 Post(s)
mrboca, thanks. Since I have cleared the code, all is good, I am not getting any messages on Instrument cluster.
I believe the way system is design is that when IC sees the low resistance in the system, it create code B112B and display on IC the message Coolant Low Level. So look like the logic in instrument cluster is that on low resistance or Mercedes call it short circuit, it will display the message Coolant Level Low.
One other observation is that when I removed the connector from washer fluid level sensor, I was getting no message. It means if there is open circuit, the instrument cluster doesn't display any messages.
Anyhow, all the connectors are connected as normal for washer fluid level sensor and coolant expansion tank level sensor. I have been driving the car and no more message.
When I get some time, I am just going to remove the instrument cluster and quickly read the resistance on IC connector IB terminals 4 and 12. This will give me full loop resistance when Coolant Expansion tank is full and windshield washer reservoir is full also. I will keep you posted.
Name:	5-13-2019 10-46-38 AM.jpg
ID:	2512376   Click image for larger version
Name:	5-13-2019 10-55-10 AM.jpg
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #16 of 24 (permalink) Old 05-13-2019, 11:48 AM
You probably had an intermittent short on the line which caused the IC to read a short.
I do not think the IC has the capability to display both coolant and the washer fluid low message in case of a short detection on the line, so it displays the washer fluid low message by default, with an error code.
It is also important to note when the actual test is done. In my experience, the washer fluid low message pops up when you turn the contact, and I think it would give implausible value if the test is done when the car is moving due to fluid sloshing in the container. So if you had the fault cleared and then pulled the connector while the key is in position 2, it may not register.
post #17 of 24 (permalink) Old 05-14-2019, 07:46 AM Thread Starter
Quoted: 26 Post(s)
mrboca, thanks for your reply. As of today, I have not seen any more message on IC for Low coolant level.
I will check the circuit from IC side by removing IC and then taking Ohms reading from Electric bracket B just to see what will be the total loop resistance that goes through coolant lever sensor and washer fluid level sensor.
It is quite difficult to read resistance of Expansion tank coolant level sensor, the connector are way in and unless you remove the air box and then expansion tank, there is no simple way to read the resistance. I will read the resistance of Coolant level sensor via IC electrical connector plus washer fluid level sensor connector per attached IC diagram.
The Washer fluid level sensor is quite low cost, it is sold for only $16.
https://www.ebay.com/itm/153337606533?ul_noapp=true
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #18 of 24 (permalink) Old 05-14-2019, 07:53 AM
Yeah, follow the procedure, starting with item 3.0 in the attached link.
STAR TekInfo
post #19 of 24 (permalink) Old 05-14-2019, 09:50 AM Thread Starter
Quoted: 26 Post(s)
mrboca, Thank you so much for such a good info on IC and resistance of individual level sensors and over all loop resistance.
I will remove the IC this weekend and will give you update. I believe I have issue with windshield washer level sensor and NOT Expansion Coolant Tank level sensor.
Again many thanks for your time and support.
Name:	5-14-2019 9-44-56 AM.jpg
ID:	2512530   Click image for larger version
ID:	2512532   Click image for larger version
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #20 of 24 (permalink) Old 05-18-2019, 04:13 PM Thread Starter
Quoted: 26 Post(s)
mrboca, some update. Today I removed the IC and measured the whole loop resistance across Expansion coolant tank level sensor and Windshield washer fluid reservoir level sensor. The Reading I got of 154.8 Ohms. Way lower then I expected, but match what you have told me.
My reading of Windshield washer fluid reservoir level = 33.6 ohms
whole loop resistance across Expansion coolant tank level sensor and Windshield washer fluid reservoir level sensor = 154.8 ohms
It means Expansion coolant tank level sensor 154.8 ohms Minus 33.6 ohms = 121 ohms, which is good.
So my problem is the Windshield washer fluid reservoir level sensor, which suppose to be 145-185 ohms and I am getting only 33.6 ohms.
Thank you mrboca, I will get Windshield washer fluid reservoir level sensor for $16.
Below are some photos from today.
ID:	2513818   Click image for larger version
ID:	2513820   Click image for larger version
ID:	2513822   Click image for larger version
ID:	2513824   Click image for larger version
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
Got Codes? Check this list Check Codes W210 E-Class 80 06-12-2017 09:00 PM
FS: parting out several 98,99,00,01 ML's sc_mopar For Sale/Wanted/Trade/Giveaway 1 01-21-2016 01:06 AM
Code Help! jporrata W202 C-Class 10 07-31-2009 08:02 PM
Check engine light e320 cc238 W210 E-Class 16 06-26-2009 05:47 AM
Oxygen Sensor Tech Bazzle R170 SLK-Class 3 12-11-2007 03:36 PM
