1996 E320 won't start after low battery - Page 7 - Mercedes-Benz Forum
post #61 of 71 (permalink) Old 01-27-2019, 11:15 AM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 215 Post(s)
I read:
- a pulse charger/tender/maintainer is “better” (I don’t remember in what way) than a constant trickle charger.
- CTEK, PulseTech and Deltran are quality brands for battery maintenance.
- MB labeled devices for seasonal use vehicles are made by CTEK, if that’s an endorssement.
Sixto
02 C320 wagon
tabijan is offline
post #62 of 71 (permalink) Old 01-27-2019, 11:38 AM
Date registered: Jul 2014
Vehicle: 1998 e430
Quoted: 28 Post(s)
I like my Deltran . Use it on my BMW r1200 gs Motorcycle. I would recommend theirs.
https://www.ebay.com/itm/Deltran-Bat...frcectupt=true
southpaw is offline
post #63 of 71 (permalink) Old 01-27-2019, 11:40 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 770 Post(s)
You will find CTEK chargers at MB, BMW and Porsche dealers for three times the price for the logo.
I use two CTEK MUS4.3 chargers. Pulse function "exercises" battery simulating normal daily use.
For backup I keep NAPA branded 10 A dummy charger. Smart chargers don't work on completely discharged batteries.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #64 of 71 (permalink) Old 01-27-2019, 12:02 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 206 Post(s)
with the evolution of battery compositions the past decade(s) or so, what is
important is to match the charger with the battery type. if you're getting AGM
or spiral wound or gel or lithium (you get the idea) it no longer becomes a
one-size-fits-all when it comes to proper charging. investing in a higher tech
battery means using the correct charger in order to maintain proper health.
read up on the manufacturer's recommendation
raymond-
47º34'N 122º18'W
raymond- is offline
post #65 of 71 (permalink) Old 01-27-2019, 02:01 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1107 Post(s)
Send a message via Skype™ to mrboca
I was considering CTEK till someone brought me a dead one, for me to find out what was going on. It was slightly bulged, and no sign of life at all. Maybe some quality control issue. Ended up in the garbage bin.
mrboca is offline
post #66 of 71 (permalink) Old 01-27-2019, 02:13 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 770 Post(s)
They do get hot. I wish bottom part was made out off aluminum to act as heat sink. Newer ones simply back off charging current when they get too hot.
Still, for safety any charger needs to be placed in ventilated area outside of vehicle.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #67 of 71 (permalink) Old 01-27-2019, 06:58 PM
Date registered: Jun 2011
Vehicle: 2001 E320 RWD- 2011 E350 4M
Quoted: 16 Post(s)
I was thinking about opening a new thread but this seems sort of related, issue is not with my car but a friend of a friend lol.
Same thing, after the vehicle sits about 2.5 to 3 months, no juice in the battery and even with a new battery he gets “Remove Key” error which I never seen before, any ideas?
It is a 2001 E320
01blackhawk is offline
post #68 of 71 (permalink) Old 01-27-2019, 08:41 PM
It is a 2001 E320
It is probably a good idea to start a new thread, because the problem you mention is more likely an issue with ESL / EIS which the 1996 E320 does not have (infra red signaling between the key fob and the ignition switch).
Is the steering locked ? can the key be removed and reinserted ? Does the car crank and start ?
mrboca is offline
post #69 of 71 (permalink) Old 02-04-2019, 03:59 PM Thread Starter
Date registered: May 2013
Vehicle: 1996 E320 and 2015 GLK350
Quoted: 10 Post(s)
The new K40 arrived today and within a few minutes, the module was installed and the car started right up! Yay!!
A special "Thank you!" to mrboca and Witek_M for all of your help, links to schematics and patience in walking me through the troubleshooting. We isolated the problem to the K40, proved that the K2 relay was bad and replaced the defective part. I learned a lot along the way. And I'm especially glad that it wasn't the CPS sensor -- I still can't find the darn thing!
raymond- and Witek_M like this.
AnthonyA860 is offline
post #70 of 71 (permalink) Old 02-04-2019, 04:02 PM
mrboca is offline
