Key in 2000 E series wont turn - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-18-2018, 02:37 PM Thread Starter
Date registered: Sep 2018
Vehicle: 2000 e series
Send a message via Yahoo to dinows333
Got in my 2000 E series today and the key will not turn. Battery is hot and has been running fine any ideas ? is there a overide to start the car ? Thanks Deano
dinows333 is offline
post #2 of 12 (permalink) Old 09-18-2018, 03:33 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 829 Post(s)
Are you saying the key will not turn in the ignition?
or that the key turns, but the starter does not work?
Why is your battery hot?
How many volts/amps on your battery? Take the battery to parts store and have them test it. Batteries wear out, good one day, bad the next. (actually they degrade over time until they no longer work) Clean your battery terminals and make sure the connection is tight.
There is no "overide" you must turn the key in the ignition to start the car.
rumb is offline
post #3 of 12 (permalink) Old 09-18-2018, 03:41 PM
Harv81's Avatar
Date registered: Sep 2011
Vehicle: '00 E55 AMG - '80 300SD - '83 240D
Quoted: 162 Post(s)
Key is dead or EIS is bad.
Harv81 is offline
post #4 of 12 (permalink) Old 09-18-2018, 06:46 PM Thread Starter
Is there a battery in the key ?
post #5 of 12 (permalink) Old 09-18-2018, 06:48 PM Thread Starter
When I said the battery is hot I meant it was up to par, tested it with a load tester. Key will not turn at all worked fine yesterday
post #6 of 12 (permalink) Old 09-18-2018, 06:57 PM
Harv81's Avatar
Quoted: 162 Post(s)
Yes, BUT that battery only controls the lock/unlock function in the key. Not the key function that makes the connection to the car.
What does the little info screen say when you insert the key into the dash?
Harv81 is offline
post #7 of 12 (permalink) Old 09-18-2018, 08:28 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 275 Post(s)
Do you have another key to try?
illstplaya is offline
post #8 of 12 (permalink) Old 09-18-2018, 08:36 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
More than likely the key is bad. It goes bad if the key is dropped few times. Usually a broken coil inside.
mrboca is offline
post #9 of 12 (permalink) Old 09-19-2018, 06:22 AM Thread Starter
Key will turn on the flashers, horn, door unlock but will not turn the ignition. in the little info screen it says "CODE"
post #10 of 12 (permalink) Old 09-19-2018, 09:38 AM
No idea which screen you are talking about. The one on the dash? Maybe you should post a picture of it. If the doors unlock, and parking lights blink when you lock, it explains that the remote part is working. But this is separate from the ignition part of the key.
If you do not have a spare key, you should get one from the dealer, and then get the key you have now repaired as the spare key. There is a gentleman who frequents this forum who can repair your key at a reasonable cost, if repairable.
mrboca is offline
