R12a vs R134a - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-23-2018, 06:06 AM Thread Starter
Date registered: Jan 2018
Vehicle: 2002 E320
Quoted: 2 Post(s)
R12a vs R134a
I recently replaced my AC compressor and expansion valve on my 2002 E320. I flushed the system (lots of fluid came out) and then filled it with R134a. It is cooling but not cold.
So; if I replace the R134a with R12a will it be colder?
Any change in capacity or recommended pressures?
Thanks,
Timsawdey is offline
post #2 of 12 (permalink) Old 07-23-2018, 07:42 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 691 Post(s)
Try R290
Triggering religious fanatics since 1969
tjts1 is offline
post #3 of 12 (permalink) Old 07-23-2018, 07:46 AM
Kajtek1's Avatar
Quoted: 1979 Post(s)
Can you buy R12 without a licence?
The media are not mixable and even conversion is technically possible (I converted W123 to R134) don't think you will benefit.
Even my commercial freezer runs on R134.
Do proper system troubleshooting per link in stickies.
Kajtek1 is offline
post #4 of 12 (permalink) Old 07-23-2018, 07:51 AM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 492 Post(s)
Thanks,
What kind of fluid came out? Did your old compressor grenaded.
Did you recharge by weight? Did you replace the dryer/receiver?
260e crusier is offline
post #5 of 12 (permalink) Old 07-23-2018, 07:56 AM
Harv81's Avatar
Date registered: Sep 2011
Vehicle: '00 E55 AMG - '80 300SD - '83 240D
Quoted: 162 Post(s)
Yepp. I bought three cans for a guy with a C4 Corvette last week.
Harv81 is offline
post #6 of 12 (permalink) Old 07-23-2018, 11:46 AM Thread Starter
Vehicle: 2002 E320
Quoted: 2 Post(s)
The fluid looked like a cleaner solution
It was not the oil in the compressor.
post #7 of 12 (permalink) Old 07-23-2018, 11:57 AM
tjts1's Avatar
Quoted: 691 Post(s)
tjts1 is offline
post #8 of 12 (permalink) Old 07-23-2018, 12:00 PM
Kajtek1's Avatar
Must cost you a fortune?
But 3 cans is marginal for initial charge. What when you will need more?
Still even R12 suppose to have better cooling capacities, you will inject it in system not design for it.
R134 did freeze our windshield in Texas climate when W124 had small malfunction, so not that is bad refridgerant.
Kajtek1 is offline
post #9 of 12 (permalink) Old 07-23-2018, 01:15 PM
Date registered: Mar 2010
Vehicle: 88 560SL - 01 C240 - 02 E320 4matic Wagon
Quoted: 72 Post(s)
The pressures are different .....
If you have a compressor failure -- you do need to flush the system .. but it's not always successful. The R/D needs to be replaced .. and often the condenser.
Did the new compressor come with oil installed?
Proper pump down and refrigerant fill is required.
I recently had my condenser and R/D replaced (damage) by my independent --- it's working better than ever -- MB fixed it twice previously ...since I bought it in 2010.
yeldogt is offline
post #10 of 12 (permalink) Old 07-23-2018, 01:55 PM
Harv81's Avatar
Quoted: 162 Post(s)
$100. Real R12. Still be made in other countries.
Harv81 is offline
