Key wont turn - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-30-2017, 08:44 AM Thread Starter
Date registered: Oct 2017
Vehicle: 2000 e320
Quoted: 2 Post(s)
Unhappy Key wont turn
Hello all,
I am trying to see why my 2000 e320 wont turn
this is what happened, went into walmart came out put key into ignition and cant turn key left or right,
I checked my battery twice at autozone and orilleys, getting 12 v, I checked every single fuse in the car, my key will
unlock the doors fine.
I didnt want to spend 400 bucks on a key that may or may not fix issue.
baiotelecom12869 is offline
post #2 of 10 (permalink) Old 11-01-2017, 02:16 PM
93SoCal400E's Avatar
Date registered: Jul 2008
Vehicle: 2005 CLK500 w/30K
Quoted: 81 Post(s)
Accuracy on these numbers is important.
12.0 Volt is dead (won't start)
12.4 Volt is low
12.5 or 12.6 is good
Have you dropped the key recently?
The start circuit and unlock circuit are separate. It is possible for one to work and not other.
Also possible EIS died.
93SoCal400E is offline
post #3 of 10 (permalink) Old 11-01-2017, 02:25 PM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 962 Post(s)
12.0V should still turn the car over. I've seen batteries at 11.8V that could turn over the engine. Plus, the key should still turn even with low battery.
Sounds like dead EIS if he can't even so much as turn the key.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #4 of 10 (permalink) Old 11-02-2017, 07:32 AM Thread Starter
Vehicle: 2000 e320
Quoted: 2 Post(s)
I did go to junk yard and geta ignition switch(EIS) module, it did the same thing. benz dealer says it has to be married?
post #5 of 10 (permalink) Old 11-02-2017, 09:27 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 377 Post(s)
Should be posting here: https://mbworld.org/forums/e-class-w210-2/ - pull board and check key internals.
konigstiger is offline
post #6 of 10 (permalink) Old 11-02-2017, 09:41 AM
Harv81's Avatar
Date registered: Sep 2011
Vehicle: '00 E55 AMG - '80 300SD - '83 240D
Quoted: 162 Post(s)
Of course. If Mercedes didn't do this, every car thief would be flatbedding Mercedes away then swapping in new EIS and driving away.
Harv81 is offline
post #7 of 10 (permalink) Old 11-02-2017, 09:57 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
The key not turning and the car not starting are two different issues. If the battery is weak, but not too weak to open the doors, it is very likely that it is not too weak to turn the key in the EIS. If the key turns but the battery cannot maintain at least 10V while cranking, than it would be an battery issue.
I would just get one of these to determine whether the key or the EIS is bad.
https://www.ebay.com/itm/Car-Lock-Co...FZZhea&vxp=mtr
If you need one urgently, you can make your own with some thin wire and a small LED.
Alexander.Luthor likes this.
mrboca is online now
post #8 of 10 (permalink) Old 11-03-2017, 07:44 AM
Date registered: Nov 2011
Vehicle: 2001 E320 - Karl; 2000 ML55 AMG - Klaus; 2005 ML350 - Gertraud (daughter's car)
Location: South East Louisiana, USA, North America, EAtrth
Quoted: 64 Post(s)
had this same issue 3 weeks ago. it's the key. can only get it from a dealer. you 'might' be able to find someone to repair it. the EIS doesn't require much voltage but the key internals must be working. price the key at EVERY dealer within driving range AND be prepared to bring the car there when it comes in. someone might know a dealer that does not require the car to be there, but all 5 dealers in my reasonable area did. and the prices ranged from $280 to $500.
good luck
98 e320 white 202K (totalled)
01 e320 black 158K ... black beauty (for sale)
00 ML 55 Azure blue 134K ... beast mode
05 ml350 black 105K (daughter's car thank GOD)
08 e350 red ... the new sled.
rvschulz is offline
post #9 of 10 (permalink) Old 11-03-2017, 08:24 AM
Quoted: 962 Post(s)
Car thieves do this anyway. Remember, the chop shops have the EEPROM programmers to "re-virginize" EIS's and reprogram them to the cars. This move by M-B has very little to do with any anti-theft concerns and much more to do with trying to force people to go to the M-B dealer when things go bad, so M-B makes more money. It's all about the Benjamins, baby....
cowboyt is offline
post #10 of 10 (permalink) Old 11-03-2017, 09:35 AM
I think MB dealers are more interested in selling you brand new Benzes when your car is stolen, rather than selling keys. They have pressures from the insurance industry to make sure that you are the owner. That is why I believe they had to come up with all these TRP policies. If they dispatched keys to every Tom Dick and Jerry who claim they owned the car, they would be in a lot of hot water with courts. There may be some dealers who are willing to bend the rules, and supply you the keys with minimum documentation.
