W210 replacing front seat back upholstery - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-21-2017, 04:59 PM Thread Starter
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 216 Post(s)
I happened upon a wrecking yard W210 with sheepskins on the front seats. As expected, the seat surfaces were dull but with no sign of wear. Rather than fit complete seats of unknown age and function to my car with seats that work, I removed the upholstery (and attached padding) to transfer to my car. Here's how *I* replaced seat back upholstery. I'll document the seat bottom process later.
Tools: T-20 Torx driver, flat blade screwdriver (to pry), hammer, possibly an awl or ice pick (cue Bernard Herrmann score)
Time: once I figured out how to remove the upholstery, it took me 10 minutes to remove and 10 minutes to install working methodically and checking my work.
Procedure:
Remove two screws from along the bottom of the rear cover using a T-20 driver.
Pull the rear cover down and away from the seat. Set aside.
Use a flat blade screwdriver to spread the fingers of the socket holding the end of the head rest posts to the riser mechanism. Pull up firmly on the post to release from the socket. Repeat for the other post. It appears that you can just jerk the headrest posts out of the sockets but I didn't want to chance damage. Lower and/or recline the seat as necessary to remove the head rest.
The upper hem of the upholstery tucks into a notch along the upper rear edge of the seat back frame. A screwdriver tip is in the notch in this picture taken from ahead of the seat.
Pull the hem forward and free of the notch starting at the corners. The head rest riser gets in the way towards the middle but there's enough room to remove the hem. I would have tried something like an awl or ice pick if necessary but my fingers were strong enough.
Reach under the upholstery just released and feel for the tab holding the head rest guide to the seat frame. Press the tab towards the front of the car while lifting the guide. Pull the guide free of the seat. Repeat with the other guide. It's possible that a quarter counterclockwise turn of the guide as viewed from above would free the guide. I forgot to check with the upholstery off.
There are 5 hooks along the bottom holding the lower hem in place. It might be possible to simply unhook the upholstery but I bent the hooks outward to make it easier. I found it easier to first unhook the leather then the backing material.
The side hems have a plastic strip that hooks to vertical posts in the seat back frame. Pull the plastic strips toward the seat centerline to release them from the frame. I pushed the slots in the plastic strips with a flat blade screwdriver. Repeat for three attachment spans on each plastic stirp.
There are 2 more hooks just above and outboard of the hooks above. Bend those hooks ouward as well. Then unhook the lowest plastic strip slot.
Take the lower ends of the side bolsters and curl them toward the centerline of the seat to unhook them from the seat back frame. Pull the bolsters forward as they release. Mind that the upholstery pad lower section has a flap that hooks to a metal rod along the bottom of the seat back frame, and the lower hem released from the five hooks have to come through the break between the seat back and seat bottom. Pull the upholstery up and away from the seat back frame.
Installation is the reverse. Set the replacement upholstery firmly on the upper part of the seat back frame. Work the side bolsters onto the corresponding edges of the seat back frame. Working through the seat back frame coil, hook the flap on the lower edge of the padding on the same metal rod along the bottom of the seat back frame. Send the lower hem through the break between the seat back and seat bottom. I found it easier to first hook the white backing material then the leather hem. Clip the plastic strips along the side hem onto the vertical frame members and lower end hooks. Tap the hooks back as they were. Feed the upper hem into the notch along the upper end of the seat back frame. Press the head rest guides into place noting the orientation of the retaining tabs. The lower end of the guides fit into corresponding holes in the seat back frame. I used my finger to align the guides with these holes. Tuck the upper hem into the notch along the upper seat back frame. Fit the head rests ensuring the post ends properly engage the sockets in the riser mechanism. Poke new holes in the lower hem for the rear cover screws. Slip the upper tabs of the rear cover under the upper hem area then position the rear cover so the screws can be tightened.
Sixto
raymond-, fosmith and MTUser like this.
tabijan is offline
post #2 of 5 (permalink) Old 08-24-2017, 06:32 AM
fosmith's Avatar
Date registered: Jun 2008
Vehicle: 2001 E430 217K mi. Obsidian Black metallic, Ash/Orion Grey interior
Quoted: 161 Post(s)
Sixto,
Great writeup. Thanks. Looking forward to your writeup for the bottom seat cushion part as that's on my list of things that need doing on my car. Does the seat need to come out to do the bottom one or can that be done with it in the car?
Fred
fosmith is offline
post #3 of 5 (permalink) Old 08-24-2017, 09:58 AM
Kajtek1's Avatar
Quoted: 1979 Post(s)
I did skin replacement and fit W210 skins on R129.
You better pull the bottom out for replacement. Technology with the stiffened rim making U-turn around the frame is the same, but more tension, so the best is flip the seat upside down on a bench, or good table, put your weight on it and then pull out the rims.
Having seat movable, all you need is take off 4 floor bolts and unplug electrical. You might need to loosen some side brackets for better access.
Kajtek1 is offline
post #4 of 5 (permalink) Old 08-24-2017, 09:43 PM Thread Starter
tabijan's Avatar
Quoted: 216 Post(s)
Plus the passenger side has a weight sensor or such that's difficult to plug/unplug with the seat in place.
Sixto
tabijan is offline
post #5 of 5 (permalink) Old 08-27-2017, 01:23 AM
Daniel Dror's Avatar
Date registered: Sep 2016
Vehicle: 2002 E320 AVANT GARDE JDM
Quoted: 11 Post(s)
Is that rubberized horsehair? I remember that stuff in my old BMW 2002. Surprised to see it in modern Benzes.
Daniel Dror is offline
