W210 valve cover gaskets - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-22-2016, 11:49 AM Thread Starter
Date registered: Nov 2015
What's the easiest way to get the Allen key bolts off the valve cover on a 97 e420? The last 3 bolts I can't seem to get, the socket hits the firewall before I can even get close to the bolt. I have to do both sides and I'd rather not pay 500$ a side at my local euro repair shop.
Also, while I'm in there I'm going to replace the little oil tubes that oil the lifters, is there a specific brand that lasts longer than OEM? Thanks
mercedesnoob is offline
post #2 of 8 (permalink) Old 01-22-2016, 01:30 PM
CafeRacer87's Avatar
Date registered: May 2014
Vehicle: 1998 E320 4matic Wagon, 1981 Yamaha Maxim XJ650
Quoted: 18 Post(s)
When I'm cramped for space, I use something like the 1/4" adapter all the way on the right in the photo below, I put it into a ratcheting wrench and use a torx/allen bit to remove or install hard to reach screws:
https://encrypted-tbn1.gstatic.com/s...zlD2u&usqp=CAY
The adapter I'm talking about has a 1/4" hex just like a bit driver does, these kits can be found at Sears, Harbor Freight, or your local auto parts store for around $10 or $20.
dlafever likes this.
CafeRacer87 is offline
post #3 of 8 (permalink) Old 01-22-2016, 01:31 PM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 106 Post(s)
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
For hex-head screws I remember using a regular right angle hex wrench.
I used Mercedes oiler tubes when servicing the two M119 motors I had previously. You might get better information when working on this engine if you post in the W140 or R129 forums as there is a lot of knowledge swirling around over there.
dlafever is offline
post #4 of 8 (permalink) Old 01-23-2016, 04:49 AM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2013 GLK350, 2007 S550, 2002 S430, 1998 ML320. Deceased - 1974 240D, 1992 400E, 1997 E420
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 94 Post(s)
An alternative to a hex key is this product:
U-Joint Metric Hex Drivers No. UJM400 | VehicleServicePros.com
You may also want to ensure that you have an inspection mirror to check the proper seating of the valve cover gasket in the back towards the fire wall before clamping down on reinstallation.
If not already considered, probably need to replace all of the breather hoses during this job. Lastly, the funky OE clamp on the passenger side breather hose can be replace with a stainless screw clamp for easier installation.
atmsmshr is offline
post #5 of 8 (permalink) Old 01-23-2016, 07:21 AM
dlafever's Avatar
Quoted: 106 Post(s)
I've also found this little dealie to be quite helpful, although I have not seen it manufactured by anyone other than Hazet. It accepts a bunch of bits, so it really useful in tight places. The model is 2664 in case there are others out there that like to spend too much for their tools.
ID:	1752169   Click image for larger version
dlafever is offline
post #6 of 8 (permalink) Old 01-23-2016, 08:12 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 575 Post(s)
on the r129 it is a piece of cake compared to an E420. the e420 has the engine "shoe horned" into the engine compartment and partially under the firewall.
On the R129, there is plenty of space to access everthing by comparison.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #7 of 8 (permalink) Old 01-24-2016, 04:19 AM
atmsmshr's Avatar
Quoted: 94 Post(s)
I had no idea just how expensive Hazet tools are!
(Now thinking of getting my wife a complete tool chest for her birthday)
Hazet Tools - Price Comparison, test reports and product ratings on Weluma. Find the best prices now!
atmsmshr is offline
post #8 of 8 (permalink) Old 01-31-2016, 05:54 PM Thread Starter
okay ill check that out. thanks
