What Do These Warning -Error Messages on Dash Mean - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 01-15-2016, 05:06 PM Thread Starter
JonBoyOhBoy's Avatar
Date registered: Nov 2015
Vehicle: 2003 E320 Wagon
Quoted: 13 Post(s)
Exclamation What Do These Warning -Error Messages on Dash Mean
Now the latest problem with my 2003 E320 Wagon:
Please look at the pics. I am assuming this means the power brakes are failing?
It does this intermittently then stopes sometimes for weeks at a time.
Am I at risk for loosing brakes and not being able to stop the car?
ID:	1742137   Click image for larger version
ID:	1742145   Click image for larger version
ID:	1742153   Click image for larger version
JonBoyOhBoy is offline
post #2 of 23 (permalink) Old 01-15-2016, 05:11 PM
ZeBenz1's Avatar
Date registered: May 2014
Vehicle: 2000 W210 E320(Gone Now)
Quoted: 4 Post(s)
Just turn the car off and then turn it back on. This happened to my E-class sometimes and every time it seemed to just be the computers having an off moment. I think you would probably feel if the ABS or the Brake Assist was actually messed up. Just keep in mind that these are some old computers and wiring and might have the occasional hiccup.
ZeBenz1 is offline
post #3 of 23 (permalink) Old 01-15-2016, 05:14 PM Thread Starter
Quoted: 13 Post(s)
Thats exactly what I have been doing. every time this happens I turn it off and on then it resets to normal. Or I hit the reset button on the dash. Last time those lights came on what about 300 miles ago. I am just afraid I will loose the ability to stop the car on the highway and kill myself
post #4 of 23 (permalink) Old 01-15-2016, 06:46 PM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
Quoted: 478 Post(s)
When the message appears again, turn the steering wheel all the way to the right then all the way to the left for couple times and see if it disappears.
benzitch likes this.
hamada128 is offline
post #5 of 23 (permalink) Old 01-15-2016, 07:08 PM Thread Starter
Quoted: 13 Post(s)
Really?
post #6 of 23 (permalink) Old 01-15-2016, 07:09 PM
Kajtek1's Avatar
Quoted: 1966 Post(s)
You have 3 systems showing malfunction.
Very often that happens with car low voltage, so start with checking it.
If the voltage is right, that would lead toward bad speed sensor.
At this point SD scanning would be very recommended.
Calibrating turning sensors is needed for ESP, but has nothing to do with BAS and ABS.
dlafever likes this.
Kajtek1 is online now
post #7 of 23 (permalink) Old 01-15-2016, 07:22 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 486 Post(s)
I had the same sporadic problem. It was usually happening on a cold start in the morning. A voltage check on my battery showed 12.68 volts which is good, but a load test showed only 262 cold cranking amps out of 900!
I replaced the battery and the problem hasn't reappeared.
Another common cause is a bad brake light switch.
You can also have the codes read and take the guess work out of problem
260e crusier is offline
post #8 of 23 (permalink) Old 01-15-2016, 09:30 PM
hamada128's Avatar
Quoted: 478 Post(s)
Originally Posted by JonBoyOhBoy View Post
Really?
Yes, it is in your owner's manual.
post #9 of 23 (permalink) Old 01-16-2016, 02:19 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 214 Post(s)
Your problem is with the abs sensors.
It is very likely that one of the ones on the rear axle, either side, is faulty. Usually caused by a rusty abs ring...which is about to fail completely and fall off. The good news is you can get the rings for a few dollars and have someone put it on for you.
Try driving at about 70 with cruise control...it will likely cancel out quite soon after turning it on.
renault12ts is offline
post #10 of 23 (permalink) Old 01-16-2016, 09:01 AM
Quoted: 486 Post(s)
CC will NOT activate with ESP/BAS/ABS lights on.
