Looks Like the 2003 E320 Wagon I bought on Ebay is a LEMON - Page 4 - Mercedes-Benz Forum
post #31 of 37 (permalink) Old 01-23-2016, 01:58 PM Thread Starter
JonBoyOhBoy's Avatar
Date registered: Nov 2015
Vehicle: 2003 E320 Wagon
Quoted: 13 Post(s)
Originally Posted by Kajtek1 View Post
Your indy is not cheap, but that happens when you don't DIY.
I would double check leveling valve as $500 looks high and it might need simple adjustment.
Amazon has them for $410 but I see them on other sites as low as $260, but I get it- all shops jack up the prices of parts. Yea I wish I could do the work myself but I don't have the time or the mechanical talent.
I was told the rear shocks aren't leaking, then another guy told me the right rear has a very "slight" leak. I'm wondering if this will get worse when the fluid is pumped to the shocks under high pressure
JonBoyOhBoy is offline
post #32 of 37 (permalink) Old 01-23-2016, 02:58 PM
wagonz's Avatar
Date registered: Feb 2010
Vehicle: '02 E320 4matic Wagon
Quoted: 14 Post(s)
I would try adjusting first, assuming you can loosen the adjuster nut. Probably pretty rusty. Hate to take those lines off, may open a can of worms.
wagonz is offline
post #33 of 37 (permalink) Old 01-25-2016, 04:51 PM
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 266 Post(s)
From my SE Michigan perspective the underbody rust seems normal. Can't comment on the body rust.
The oil level sender requires removal of the lower oil pan. Not the end of the world, just reality.
I'd recheck to confirm its really the source before changing it.
On my '98 E320 the sender will occasionally send low oil messages usually during cold weather. None are true.
You suspension concerns seem more important for the moment.
Car looks OK from the pictures.
All the best, Skippy
Skippy,
SkippyJasper is offline
post #34 of 37 (permalink) Old 01-30-2016, 06:36 PM Thread Starter
Quoted: 13 Post(s)
Well, there it is. another $2300 into the car. The gas lines were indeed rusted badly and liking, and so was the Hydraulic fluid lines, those weren't leaving though. And the level valve looked like it wa sitting on the bottom of the sea. But the car is now sitting at the right level. Did I over pay?
Now I am married to the car. If I sell it its an instant and painful loss. I NEED to get my moneys worth on the car, which translates into 3 years without any more MAJOR repairs
post #35 of 37 (permalink) Old 01-30-2016, 06:57 PM
Kajtek1's Avatar
Quoted: 1961 Post(s)
Even if you buy 12 months old car, you will have to spend at least $500 for the scheduled service at dealer.
So frankly spending $2300 for car bought at auction with lot of problems known to address is cheap IMHO
Good luck with driving.
I can't guarantee you will drive it for 3 years without another bigger repair, but at least you have a base that once you fix the problem, it should not come back 6 months later .
Kajtek1 is offline
post #36 of 37 (permalink) Old 01-30-2016, 08:40 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 752 Post(s)
Well, if it's any consolation, the motor mount replacement is CHEAP....especially since you have 4matic.
MAVA likes this.
Deplore is offline
post #37 of 37 (permalink) Old 01-31-2016, 05:40 PM Thread Starter
Quoted: 13 Post(s)
that makes me feel better, they were shot. Looked like cracked
pancakes full of oil.
