Rear is LOW. Is this a Shock issue? - Page 3 - Mercedes-Benz Forum
post #21 of 44 (permalink) Old 12-20-2015, 08:56 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 752 Post(s)
Just so you know what I'm talking about:
https://www.benzworld.org/forums/8670073-post2.html
It's the shiny block in the first picture. #180 in the 3rd picture.
Deplore is online now
post #22 of 44 (permalink) Old 12-20-2015, 08:59 PM Thread Starter
JonBoyOhBoy's Avatar
Date registered: Nov 2015
Vehicle: 2003 E320 Wagon
Quoted: 13 Post(s)
I see. My problem is I don't have the time to do this myself. I need to find a local mechanic in the Yonkers area who won't rip me off, and who knows how to do it
JonBoyOhBoy is offline
post #23 of 44 (permalink) Old 12-20-2015, 09:03 PM Thread Starter
Quoted: 13 Post(s)
Just to add something I just realized, the steering is very tight when the car is not moving. I mean, its tighter then usual. of course once its moving its fine. I assumed its just the way the car is made. Since its the same system that controls the rear suspension, could this be related?
post #24 of 44 (permalink) Old 12-20-2015, 09:09 PM
SDS Guru
Deplore's Avatar
Quoted: 752 Post(s)
I'm sure there has to be someone trustworthy. Given your comments about the mechanics recommendation to replace shocks and struts and whatsnot.... you need to find someone who actually knows MB, not those who occasionally work on one.
If the rear end is sagging, then you only need to find out why its sagging and replace the offending part. Anybody who recommends replacing struts, power steering pump or anything that leads into 4 digit invoice, run. They don't know what they're talking about....alternatively, they want to take advantage of a clueless owner. I don't know which is worse.
Either way, run.
First, educate yourself on how the system works, what it is supposed to do, what is a wear and tear item, and what is a item that is only needs to be replaced when it goes bad, and then you'll be better equipped when dealing with mechanics...even reputable ones.
Now:
Power steering pump (this is the pump that also controls the hydraulic pump) -- only replace when leaking or not working.
Struts -- only replace when leaking
Level valve -- only replace when rear end sags (which is happening in your case... better to verify first)
Accumulators -- replace when you experience harsh ride over bumps. This is a wear and tear item. (this is a item that absorbs the vibration and shocks from the road. If it goes bad, you will feel the road that much more and the noise will be very bad)
Hydraulic fluid needs to be flushed every now and then. Doing it on the same schedule as a power steering flush is a good idea (once ever year)
post #25 of 44 (permalink) Old 12-20-2015, 09:13 PM
SDS Guru
Deplore's Avatar
Quoted: 752 Post(s)
Okay, this is new. Tighter than usual in what relation? Do you actually have to exert force to turn the steering?
At idle and at a stop, it should be very easy to turn the steering wheel. Finger light, even.
post #26 of 44 (permalink) Old 12-20-2015, 09:16 PM Thread Starter
Quoted: 13 Post(s)
no not with a finger for sure. at idle or stop I have to use a bit of force. I am talking about full turning, like a U turn, not small half turns.
post #27 of 44 (permalink) Old 12-20-2015, 09:46 PM
Kajtek1's Avatar
Quoted: 1966 Post(s)
Would you have your PS pump failing, you'd really know it by now.
I am strong 210lb man, but when belt felt off our MB, I had hard time to make turns without PS assistance.
So this is good sign that your PS pump works. To make full troubleshooting you would need high pressure gauge, but I think checking the adjusting valve Dpl mentioned is easy enough to start.
Kajtek1 is offline
post #28 of 44 (permalink) Old 12-21-2015, 05:07 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 214 Post(s)
Duplicate post
renault12ts is offline
post #29 of 44 (permalink) Old 12-21-2015, 05:07 AM
Quoted: 214 Post(s)
I don't think your rear is sagging...it looks about the same as mine. I do think however that your front is very high...and that's where the problem lies.
I am surprised at the level of misinformation from owners of W210s on the W210 forum.
Your car only came with hydraulic rear suspension as every e class estate car has for nearly 40 years. The height of the car...unless you have a load in the back, is determined by the springs...which you say are new.
The tight steering means nothing in relation to the rear end. Even if the fluid leaks out entirely, which happened to me once, the rear will not sag.
Your problem is at the front. I mean look at it..it looks ridiculous. If the rear did sag it wouldn't consequently raise the front!
post #30 of 44 (permalink) Old 12-21-2015, 05:13 AM
Quoted: 214 Post(s)
My car is fitted with parameter steering...it has never been finger light at standstill. Once moving it is.
This is not a hydaulic problem...it's the front which has been fitted with new springs, like the back...but the WRONG ONES.
