Rear is LOW. Is this a Shock issue? - Page 2 - Mercedes-Benz Forum
post #11 of 44 (permalink) Old 12-20-2015, 07:53 PM Thread Starter
JonBoyOhBoy's Avatar
Date registered: Nov 2015
Vehicle: 2003 E320 Wagon
Quoted: 13 Post(s)
OK, I will go downstairs now and take some pics with my cell phone. give me 30 min please
JonBoyOhBoy is offline
post #12 of 44 (permalink) Old 12-20-2015, 08:00 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 752 Post(s)
take a picture of the engine bay too. The hydraulic res is right next to windshield washer res.
Deplore is offline
post #13 of 44 (permalink) Old 12-20-2015, 08:13 PM Thread Starter
Quoted: 13 Post(s)
Shoot I didn't see your message about the engine bay. But here are the shocks as best as I could lay under the car
ID:	1713298   Click image for larger version
ID:	1713306   Click image for larger version
ID:	1713314   Click image for larger version
post #14 of 44 (permalink) Old 12-20-2015, 08:18 PM Thread Starter
Quoted: 13 Post(s)
Those do look like hydraulic right? I can see the hose at the top. So then the mechanic was going to screw me by ordering these standard shocks and charging my $750 to install which would do nothing. right? "Mercedes Shock Absorber Rear (E320 CLS500 CLS63) - Bilstein 24-105927"
post #15 of 44 (permalink) Old 12-20-2015, 08:30 PM Thread Starter
Quoted: 13 Post(s)
If the fluid in the hydraulic res were low would that cause the rear to sag? Also, wouldn't I get an error message on the dash? I
post #16 of 44 (permalink) Old 12-20-2015, 08:43 PM
SDS Guru
Deplore's Avatar
Quoted: 752 Post(s)
Yes, if the fluid was low it'd cause sagging. Now, if it is indeed low, then you need to find out where the fluid is going. Is there a leak? Is one of the accumulators bad?
I don't think W210 has a light on the dash about the rear being too low, but I could be wrong.
Also: you have hydraulic struts. You have springs and struts. Right now you have no fluid, or a hydraulic leak somewhere, so the car is resting on the springs.... which really isn't designed to handle the weight of the car. It's meant to supplement the strut.
Deplore is offline
post #17 of 44 (permalink) Old 12-20-2015, 08:47 PM
Kajtek1's Avatar
Quoted: 1966 Post(s)
To add to what Dpl said, look for different mechanic.
Check for deteriorated hose around the pump on engine. Is your PS working well?
Kajtek1 is offline
post #18 of 44 (permalink) Old 12-20-2015, 08:47 PM Thread Starter
Quoted: 13 Post(s)
No, I just checked. the fluid is right at the Max level. So its not low. Now what to do?
post #19 of 44 (permalink) Old 12-20-2015, 08:50 PM Thread Starter
Quoted: 13 Post(s)
In general, with the sagging rear, what generally needs to be done? do the hydraulic shocks need replacing or is it the whole system? this is frustrating. I am glad I found this out tonight, I was supposed to bring the car to that mechanic tomorrow \
post #20 of 44 (permalink) Old 12-20-2015, 08:52 PM
SDS Guru
Deplore's Avatar
Quoted: 752 Post(s)
Interesting, if the hydraulic fluid is at max, and there is no leak, then it does sound like the level sensor/valve level in the back is shot.
Try this....turn off the car, have a couple people sit in the back seat so the rear end sags...then start the car. The car should rise up to the proper level.
If it doesn't -- and there is no leak -- then it does point to a bad level valve.
Also, I second Kajtek -- is your power steering working?
Deplore is offline
