lug bolts - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-23-2015, 10:45 PM Thread Starter
Date registered: Mar 2015
lug bolts
I have a 98 e320 want to put some aftermarket mono block rims on it but the factory lugs won't work. What size lugs will work for me?
tkq32 is offline
post #2 of 2 (permalink) Old 03-24-2015, 12:00 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
1. What does this have to do with Maybach?
2. Without knowing the exact wheels, it's anyone's guess.
3. Contact the wheel manufacturer, they should be able to set you straight.
4. Go to a good wheel & tire shop; they also should be able to set you up.
Good luck.
Check Codes is offline
