cracked speed sensor (one on the conductor plate)? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-15-2014, 08:53 PM Thread Starter
Date registered: Mar 2012
Vehicle: 02 CL55 AMG Clone
Quoted: 4 Post(s)
so i stripped the 7mm bolt that holds on the 13 pin female connector for the 722.6xx transmission, after dismantaling the conductor plate i noticed my black sensor was cracked? the one labeled in this picture
http://i1108.photobucket.com/albums/...ps19dd555e.jpg
is this bad? why did this crack? just wondering if i should replace it while i have the valve body out of the tranny already
Looking for -
- CL55 Speedo cluster
- 03-06 cl55/cl65 brakes
ctravis595 is offline
post #2 of 6 (permalink) Old 09-15-2014, 10:22 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1225 Post(s)
I would replace it if the speed sensor is cracked. Here is a good picture of a cracked Speed sensor. See post 35:
722.6 Transmission Refresh. DIY and questions. - PeachParts Mercedes ShopForum
Do not over torque anything. Buy your self a torque wrench
1/4 in. Drive Click Type Torque Wrench
Read the valve body section starting on page 15 for torque values of the 722.6 service manual
http://www.all-trans.by/assets/site/files/722.6.pdf
All the best,
Martin
MAVA is offline
post #3 of 6 (permalink) Old 09-15-2014, 10:24 PM
Kajtek1's Avatar
Quoted: 1964 Post(s)
Is it on Ford, or Honda that you have in your profile?
Earlier plates did have weaker sensors that have been improved in later models.
Get new plate, I bought one about 4 years ago for $160.
Kajtek1 is offline
post #4 of 6 (permalink) Old 09-16-2014, 01:04 PM Thread Starter
Quoted: 4 Post(s)
Seems as though the oem conductor plate already comes with new speed sensors
Got mine for 130 shipped if anybody else was in the market recently
I presume excessive heat over time degraded the- what seems to be plastic(?) covers that pertain to each speed sensor causing them to crack. Perhaps this new conductor plate and speed sensors will resolve some very minor shifting issues I've been dealing with since my transmission swap
Thanks Martin for the helpful post, that post 35 you mention was particularly interesting in regards to the fact this speed sensor being cracked caused some limp modes for some other benz's
Curious though if I will need a hard reset with STaR to have my tranny accept the new conductor plate/ speed sensors. I always do the "shift point learning" procedure whenever doing any modifications or repairs to the gearbox though
post #5 of 6 (permalink) Old 09-16-2014, 01:08 PM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 203 Post(s)
change conductor plate no need for any computor work it is plug and play. you are not changing control unit so adaptations will still be the same.
current stable
2010 glk350-86 300e-88 300e white-66 220seb-74 230- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup-74 harley fxe-92 harley flhtcu ultra classic-2017 harley road glide special- 2018 road glide special-98 special construction harley powered.-
1mbzdoc is offline
post #6 of 6 (permalink) Old 09-18-2014, 09:13 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
Although best to do ECU/Tranny reset - search forum - after new conductor plate..
fabbrisd1 is offline
