Photo DIY- Instrument Cluster R/R with Bulb Changes. - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 07-11-2013, 08:49 PM Thread Starter
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Quoted: 154 Post(s)
Greets.
I realize there are different Variations on different years/models... but Still... I had a difficult time researching the "Type and Number" of Bulbs in the Instrument Cluster.
Surprisingly, even EPC does not give an actual Break-down of the type/# !!!
Sooo, I thought I would give "my" particular model and experience... a 1998 E320.
PLEASSEEEEE be very very Careful! These Clusters (by History) are "Sensitive" to Stresses, and have been know to Crack/Break, with is a Crazy-Expensive "Oooopppsss". Use care on both Removal AND Install!
Anyhoooo, I think the photos are self-explanatory...
G
ID:	526610   Click image for larger version
ID:	526611   Click image for larger version
ID:	526612   Click image for larger version
ID:	526613   Click image for larger version
ID:	526615   Click image for larger version
ID:	526616   Click image for larger version
ID:	526617   Click image for larger version
ID:	526618   Click image for larger version
G-AMG is offline
post #2 of 17 (permalink) Old 07-11-2013, 08:52 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
part 2
G-AMG is offline
post #3 of 17 (permalink) Old 07-11-2013, 08:58 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
part 2- Sorry, the Site has Crashed, and is not allowing any Up-Loads... I guess I'll try again later..
G-AMG is offline
post #4 of 17 (permalink) Old 07-11-2013, 08:59 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
Ok, now working
ID:	526620   Click image for larger version
ID:	526621   Click image for larger version
ID:	526622   Click image for larger version
ID:	526623   Click image for larger version
ID:	526625   Click image for larger version
G-AMG is offline
post #5 of 17 (permalink) Old 07-12-2013, 05:22 AM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 95 Post(s)
Bravo G-AMG! Yet another excellent DIY posting.
For the makeshift mechanics among us, I have used a coat hanger bent to the shape of the MB tool hook to successfully remove ICs on three different models. It takes a surprising bit of steady force to work the IC out for the first time. After that it is easier.
A small standard blade screwdriver to rotate the bulbs and then using needle nosed pliers to remove the bulb is another alternate tool setup. (But I really like the MB bulb remover).
In this model of IC, the bottom center 6 bulbs are what provide backlighting for the LCD - if the pixels are dim those bulbs might be at end of life.
atmsmshr is offline
post #6 of 17 (permalink) Old 07-12-2013, 06:15 AM
Eagleone's Avatar
Date registered: Apr 2011
Vehicle: 2001 E430 4matic
Quoted: 6 Post(s)
Thank you! As usual, an excellent write-up.
TJ.
Eagleone is offline
post #7 of 17 (permalink) Old 07-12-2013, 06:35 AM
Date registered: May 2013
Vehicle: 2003 W210 Station Wagon; 104,150 miles when purchased 5/2/2013
Quoted: 6 Post(s)
I did my IC about 3 weeks ago following the forum guidance. Mine is a 2003 E320 and the bulbs were all clearly labeled on the PC board as 1.3W. Although the shim repair described in the stickys got my temperature pixels and clock going, I remain without the shift position indicator AND I screwed up my fuel gauge. At first it was stuck at <E and I assumed that meant it was pinned as the sticky suggests and figured I'd get back to it. Over the last few weeks however the needle has gradually moved up passed F and is now half way to the temp gauge. I'm guessing this is electrical rather than mechanical. I will pull the IC again but any clue as what to look for?
Bob
lswpubrw is offline
post #8 of 17 (permalink) Old 08-08-2014, 08:49 PM
Date registered: Aug 2005
Vehicle: 1999 E320, 2001 E320, 2004 S430
Quoted: 36 Post(s)
Hi, G-AMG,
On the fourth picture, I'm not sure I understand what you mean by "once engaged, angle hooks outward ~120 degrees". Wouldn't that cause the hook to be disengaged?
cerritos is offline
post #9 of 17 (permalink) Old 08-08-2014, 09:04 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
Originally Posted by cerritos View Post
Hi, G-AMG,
Sorry, it is difficult to explain in just a few words on an annotated picture....
Once you have engaged the serrations, with the handles parallel to the ground:
Slightly move the Left handle towards the drivers door at an angle of 10 or 20 degrees.
The Right hook is angled 10-20 degrees toward the passenger door.
The whole concept is to make the Puller Tool "HookTips" FIRMLY SEAT into the Serrations.
G-AMG is offline
post #10 of 17 (permalink) Old 08-08-2014, 10:55 PM
Quoted: 36 Post(s)
Got it. It's not a rotate action, but a "lateral move" action.
Thanks for the prompt explanation.
cerritos is offline
