Need to replace transfer case. Should I use salvage transfer case? - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 10-25-2011, 03:27 PM Thread Starter
Date registered: Oct 2011
Vehicle: 99 E320 4matic wagon
Question Need to replace transfer case. Should I use salvage transfer case?
Went to my mechanic today to track down a vibration noise. He put the ears on the car and isolated the transfer case and also said it was leaking. The car has 110,000 miles on it. I only drive 6000 miles per year. Any recommendations on replacing with a salvage transfer case vs. new? Any place that sells good used or re-manufactured transfer cases? Please help
msedc is offline
post #2 of 20 (permalink) Old 10-25-2011, 04:58 PM
Date registered: Mar 2010
Vehicle: 2002 E320 4MATIC
How bad is the transfer case leaking? I had my fluid pulled and replaced for around $100. It is leaking, and I just plan on replacing the fluid every 2 years (recommendation of my mechanic and others). It is much cheaper than replacing/repairing the transfer case. Could probably have done it myself, but for what they charged it was worth it.
I am not an expert, but I would imagine it may make noise/vibrate from being low on fluid.
clickbam is offline
post #3 of 20 (permalink) Old 10-25-2011, 06:23 PM Thread Starter
Not certain how much it is leaking but I do not notice any fluid on the garage floor. The problem I notice is vibration at 40mph to 60mph. A harmonic hum/vibration is noted at around 55mph that is a slow wha, wha, wha, wha. New tire and alignment did not change.
msedc is offline
post #4 of 20 (permalink) Old 11-03-2011, 07:33 AM
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 2000 E430 4Matic, 2007 R320 CDI, 2012 E63 P30, 2013 SLK250
Quoted: 13 Post(s)
Filling my TC resolved the exact harmonic vibration you mentioned. I also have a slow leak from the TC. I just filled mine at 170k miles. Judging from how tight the plug was on, I seem to be the first one to crack it open. However, I know getting to the plug is more difficult on the wagon.
-Robert
chucelli is offline
post #5 of 20 (permalink) Old 11-03-2011, 02:08 PM Thread Starter
-Robert
Did the harmonic vibration go away immediately or did it take a while with the new fluid in the transfer case? I just had mine changed today but no immediate change in the noise that I am suffering from.
msedc is offline
post #6 of 20 (permalink) Old 11-03-2011, 03:54 PM
chucelli's Avatar
Quoted: 13 Post(s)
the bulk of it went away right after I filled it. However, there is still a very small hint of it. I assume it is from the front tire wear which resulted in the TC not being filled.
Also adding that I had been searching for the cause of this vibration for a while, but all the obvious things were ok (ie. wheel bearing, ball joints, control arm bushings...) Brand new tires and balance did not resolve either. Like you, mine also is most obvious between 40-60 MPH.
-Robert
chucelli is offline
post #7 of 20 (permalink) Old 03-21-2014, 01:28 PM
Date registered: Mar 2009
Vehicle: 2000 E430 4-Matic
-Robert
Any luck with the vibration? I have the same thing and it's been a tricky problem. I'm putting on new drive axles this weekend. Do you feel the vibration in the steering wheel? I do. Do you have original wheels? Does the vibration almost disappear as you go above say 70.
Thanks
David
Things fixed so far with the help of BenzWorld on my W210:
Rear Window regulator
Blower Regulator
Headlamp lo-beam bulb
dpompian is offline
post #8 of 20 (permalink) Old 03-21-2014, 01:40 PM Thread Starter
No changes in vibration with change of fluid in TC. The last time I was at the MB dealer that discovered vibration of drive shaft but did not tear car apart to evaluate center bearing or if out of balance. They also noted a vibration in the right wheel. Maybe bearing as tire has been balanced. The vibration is noted in the steering wheel at about 40mph.
msedc is offline
post #9 of 20 (permalink) Old 03-21-2014, 07:11 PM
Date registered: Feb 2014
Vehicle: 1999 E320
Quoted: 4 Post(s)
Look for used parts on car-parts.com they are a network that auto dismanters nationwide subscribe to list parts available. If you get a used case consider replacing the seals before installing.
Cabo21 is offline
post #10 of 20 (permalink) Old 03-21-2014, 08:20 PM
chucelli's Avatar
Quoted: 13 Post(s)
Thanks
David
No, it still exists. I can't figure it out. It doesn't seem to be consistent. Sometimes it appears at a certain speed, other times it seems to be very smooth.
I have the original wheels. It is hard to pinpoint where it is coming from. You could certainly feel it in the steering wheel. Sometimes I don't feel it at all from 70-100mph, but sometimes I do. It seems most obvious around 60-65.
Please let us know how the new axles work out. I've heard some talk of high mileage axles developing a bit of play which could cause this, but I don't know if there is any truth to that..
-Robert
chucelli is offline
Transfer Case ashleytate General Mercedes-Benz 2 07-09-2010 03:06 PM
Transfer Case cam410min General Mercedes-Benz 9 07-04-2007 06:51 AM
looking for transfer case Bansai W163 M-Class 6 03-02-2004 03:15 PM
Used Transfer case ant out there? Gerald A G-Class 14 06-08-2003 08:59 AM
VG 150 transfer case PIPO G-Class 4 03-10-2002 11:25 AM
