Side Mirror Fix - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 07-12-2010, 03:56 PM Thread Starter
Date registered: Mar 2010
Vehicle: 88 560SL - 01 C240 - 02 E320 4matic Wagon
Quoted: 71 Post(s)
Side Mirror Fix
After having my 02 Wagon for a week the one thing I am going to have to pay to fix is the driver side mirror. The dimming function has failed and I am getting a double image. Reading over the MB extended warranty -- this is not a covered item.
I am sure in addition to the dimming - it is also heated. It looks like the glass is replaceable -- not sure how hard it is to switch out?
Does anybody know if the glass is available with the heater but without the dimming feature? The MB dimming mirrors are very dark --- my Jaguar dimming mirror is almost clear.
yeldogt is offline
post #2 of 11 (permalink) Old 07-12-2010, 05:02 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
I don't know if the earlier mirror will fit in your housing, but it wasn't dimmed. It's a far shot less expensive too.
Matt L is offline
post #3 of 11 (permalink) Old 07-12-2010, 05:11 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 34 Post(s)
The reason your mirror glass is dark, and gives double images, is because it has failed. I just replaced mine and the new self dimming glass is as silver as any other mirror. I was able to replace mine with an aftermarket glass that was self dimming and heated. I paid $220 for the glass on the web. I can't imagine why it would not be a warranteed item. I believe the MB glass is about $470. I bought the glass at www.thepartsbin.com .
nelbur is offline
post #4 of 11 (permalink) Old 07-12-2010, 06:35 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 210 Post(s)
aftermarket glass is available with heat (or no heat) and w/o the dimmer
for about $30. they may even offer the wide angle coverage design for
about the same price, too.
i've had good experience with this vendor. couple of other guys on MBWorld
have, as well.
raymond-
4734'N 12218'W
raymond- is offline
post #5 of 11 (permalink) Old 11-10-2011, 11:15 PM
Date registered: Aug 2010
Vehicle: MY2005 SL350
have, as well.
I have the same problem and was quoted $800 by the local MB dealer (Sydney) for a replacement lens (!!)
This aftermarket glass sounds great, but can I ask you a couple of questions...
- does it stick / clip on top of the original mirror or do you need to take the original mirror off and then put the aftermarket on, and
- if it's the latter, can you still use the electric controls to adjust the mirror as normal?
Thank you
post #6 of 11 (permalink) Old 11-11-2011, 01:52 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 214 Post(s)
It sticks to the existing mirror. Make sure the old one is clean and dry and then just stick it on. Everything will work as normal...possibly even the defrost.
2005:
renault12ts is offline
post #7 of 11 (permalink) Old 11-11-2011, 03:06 AM
Musikmann's Avatar
Quoted: 8 Post(s)
You can also get the real deal for a little over $300 US. That's what I did, buying the replacement glass from autohausaz.com and the dealer tech (who was doing other work) popped the old off and the new on, in less than a minute.
Musikmann is offline
post #8 of 11 (permalink) Old 11-11-2011, 04:36 AM Thread Starter
Quoted: 71 Post(s)
muslkman -- did you get the OE glass with heat and dimming for $300.00? That is a very good price. I was at $500.00 -- that was the best I could do on a facelift model at that time.
What I did was to get a set of the European style anti-blindspot mirrors. These are factory MB mirror glass with a split mirror widely used in other parts of the world. They are great on a wagon -- they have heat but the driver is not dimmed .... it does have a tint. I paid I believe about $125.00 for both mirrors including shipping to the USA. The heat wires just plugged in and I capped off the dimming wires.
I did not want to go with the stick on -- as I needed the heat function to work.
yeldogt is offline
post #9 of 11 (permalink) Old 11-11-2011, 07:04 AM
Vehicle: 1997 E300D
Quoted: 34 Post(s)
If you cut away the black plastic rim around the glass, and remove the outer glass, along with the goo inside, you have a heated mirror with no dimming feature. I did not do this myself as I bought an auto dimming replacement for $230 on line, but others have removed the outer glass and were happy with the results.
nelbur is offline
post #10 of 11 (permalink) Old 11-11-2011, 07:15 AM Thread Starter
Quoted: 71 Post(s)
I have heard of people doing this -- but I heard that it does not result in a perfect mirror. The pre-facelift cars are much cheaper to replace.
yeldogt is offline
Rear view mirror and side mirror freak out! ccooper405 W140 S-Class 10 09-21-2016 07:17 AM
Changing 90 560SEL side mirror glass (mirror)? shortwill W126 S,SE,SEC,SEL,SD,SDL Class 5 05-18-2008 04:31 PM
driver side mirror different from passenger side mirror? loO4la R170 SLK-Class 8 08-02-2005 12:53 PM
How come my driver's side mirror has a black rubbery border whilst the passenger's side does not? masmole R171 SLK-Class 2 05-18-2005 06:21 AM
Ordered the 2002 side mirror covers with blinkers for CAD235 (each side) from dealer... RLO - Vancouver R170 SLK-Class 10 06-01-2002 11:34 PM
