W210 E430 AC Compressor Replacement Write-Up - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 06-26-2010, 11:51 AM Thread Starter
Date registered: Aug 2009
Vehicle: 2001 Mercedes E430 Sport
Post W210 E430 AC Compressor Replacement Write-Up
Since I have not been able to find a write-up on replacing a defective AC compressor, I took photos and created a PDF file of the write-up, attached in two parts due to size limits. Also attached some general information I used to figure out how to perform the replacement.
In my case the compressor was not mechanically defective yet, but it was leaking oil. If yours is making noises, your replacement will be much more involved. Mine was still operating just fine so I elected not to replace the expansion valve.
The car is a 2001 E430, but the E320 instructions should be identical (might even be easier to get compressor out).
Jarno
Charleston, SC
tmabiker likes this.
Jarno is offline
post #2 of 31 (permalink) Old 06-27-2010, 10:44 AM
Date registered: Feb 2007
Vehicle: 2002 E320
Nice write-up. Where'd you get your ramps and chocks?
cool_breeze is offline
post #3 of 31 (permalink) Old 06-27-2010, 02:05 PM Thread Starter
Thanks for the compliment!
The ramps are from AutoZone (12,000lb ones, they just look stronger) and the wheel chocks are from Northern Tool& Equipment.
Jarno is offline
post #4 of 31 (permalink) Old 01-30-2011, 11:21 PM
Date registered: Jan 2011
Hello jarno
Thank you for your posting, very important. Acctualy my car have some problems with Ac, it does'nt cool, the compressor turns on, but the high pressure indicators shows up... i dont know what to do
any help???
"Dreaming out Louder" is offline
post #5 of 31 (permalink) Old 02-12-2011, 04:06 PM Thread Starter
If you mean that the diagnostic on the AC control panel shows high pressure, it simply means you put too much freon in when you or someone else topped it off.
If you had it serviced, take it back and complain. They need to remove some of the freon from the low pressure port.
Do not try to release the pressure yourself, since compressor oil and freon will escape.
Jarno is offline
post #6 of 31 (permalink) Old 02-26-2011, 11:19 AM
Date registered: Apr 2010
Vehicle: E55 AMG
Just read your write up. Its people like you that really make the difference. Well done. Very interesting. Car looks great by the way.
e55amgman is offline
post #7 of 31 (permalink) Old 02-26-2011, 05:50 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
Files have been editied and condensed
Great write up - for caffienated grins I have edited and compressed the files into 3 pcs - the cleart photos just have stayed big.
1. Compressor removal and install - this is the biggest file
2. Compressor refill
3. WIS pages
fabbrisd1 is offline
post #8 of 31 (permalink) Old 02-26-2011, 08:31 PM
Vehicle: 84 300SD (2 ea.), 98 E320 4matic Wagon, 51 Chev 1T pickup, assorted british motorcycles
Great Write-up! Better than the WIS.
On another thread the OP couldn't get the fittings off the compressor in situ. So he removed the compressor from the front and above by breaking the suction and pressure hoses at the other end. He had to pull the fan and shroud. It seems to me that this might be preferable in terms of keeping dirt out of the compressor. Having never done this I don't know if it would be more trouble that it's worth to pull the compressor from the top.
Also, I note that you used the 7SBU16C rather than the 7SB16C that is called out in many parts books. I understand that the SBU is an updated version and eliminates failure problems of the SB. Where can one get the SBU and be confident of getting the quality Japanese Nippondenso unit and not a Chinese or Indian unit. It isn't clear to me from the parts listings I've seen what I'd be getting.
Thomasa98 is offline
post #9 of 31 (permalink) Old 07-02-2011, 05:37 PM
diqiu's Avatar
Date registered: Feb 2010
Vehicle: 1995 Mercedes C220, 1996 BMW 318i,
This is the best write up I have ever read. Thank you, Jamo!
diqiu is offline
post #10 of 31 (permalink) Old 07-06-2011, 02:49 PM Thread Starter
Thank you, one of these days I'll have to find time to write some more!
Jarno is offline
W210 ('01 E430) Shocks and Springs tris1969 For Sale/Wanted/Trade/Giveaway 1 06-25-2009 01:02 PM
Just got my W210, E430 4matic markwill W210 E-Class 17 01-16-2008 06:47 AM
Adding a sub to a W210 E430? Benzboy124 Audio & Telematics Forum 2 02-28-2007 07:54 PM
20's w210/e430 ? fastmike99 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-11-2007 09:59 PM
e430 (w210) Fog Lamp Replacement Benz*Chick General Mercedes-Benz 4 04-04-2005 08:22 AM
