Turn Signal Light Socket Problem - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-31-2009, 11:07 AM Thread Starter
Date registered: Jan 2009
Vehicle: 1999 E320 w/118K
Quoted: 7 Post(s)
The driver's side rear turn signal light has developped a peculiar problem of late.
I get a bulb failure indication when I do a left turn. The bulb is fine. The socket is fine (no rust or other dirt, corrosion). Everything is pristine. I did notice that the conductor plate is not tight against the taillight housing. I put a tiny paper shim between the conductor plate and the taillight assembly before replacing the bulb socket so that it connection would be very tight.
This works fine..... for about 4-5 days, then it fails again. All I do is remove the bulb socket and put it back in and it works again.... for another 4-5 days and then I have to repeat the procedure.
Very aggravating. Now what invisible culprit could possibly be causing it to fail repeatedly after 4-5 days?
Thanks
kwhombre is offline
post #2 of 9 (permalink) Old 12-31-2009, 12:31 PM
Date registered: Dec 2008
Vehicle: 1991 190E 2.6lt; 1998 E320 Wagon 4Matic; 2007 E350 4Matic; 2004 C240 4Matic
I have had similar problems on both my E320's. On closer inspection I found that the metal on the tail light assembly circuit had burned through and lost conduction. I have replaced two rear tail light assemblies. $120 at Mercedes and an easy job. When the third one went I didn't replace the assembly but when putting the bulb in I didn,t turn it the full amount, then I glued it with automotive goop...one year ago and all is fine
chiro is offline
post #3 of 9 (permalink) Old 12-31-2009, 01:58 PM
Date registered: Dec 2009
Vehicle: '03 C320 4Matic Wagon
Quoted: 2 Post(s)
"automotive goop" = ??
how about a picture chiro?
'03 C320 4matic Wagon
tmandel is offline
post #4 of 9 (permalink) Old 12-31-2009, 02:33 PM Thread Starter
Quoted: 7 Post(s)
I am trying to imagine what it is that burned through and where to look to find it.
kwhombre is offline
post #5 of 9 (permalink) Old 12-31-2009, 03:04 PM
when you turn the socket and lamp assembly into the the taillight assembly the metal tabs on the socket are pressed onto the tail light circuit and after a while they can burn through it. Pull out the tail light assembly and remove the bulb and socket and inspect the tail light circuit. If it is burnt through...then when replacing the bulb and socket assembly don't turn it in as much..the contacts will now rest on the circuit that is ok and use automotive goop or a silicone adhesive to hold the socket in place.
Hope this helps. Don'y know how to include photos..sorry
chiro is offline
post #6 of 9 (permalink) Old 12-31-2009, 03:43 PM
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
Quoted: 9 Post(s)
I have had this problem, too. It seems to be the negative, or ground, circuit that fails most often. I soldered a wire to the underside of the ground contact on the lamp socket. I then loosened a nut nearby, that screwes tight to body sheetmetal. I looped the free end of the added wire under the nut and tightened. Now I have a great ground connection. I believe there is a sticky on this. Happy New Year!
rabbit188 is offline
post #7 of 9 (permalink) Old 12-31-2009, 04:12 PM Thread Starter
Quoted: 7 Post(s)
I am relatively clueless about electrical devices. What identifies positive from negative on the socket?
Happy New Years!!
kwhombre is offline
post #8 of 9 (permalink) Old 12-31-2009, 04:22 PM
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 4Matic Estate E320S4 210.282
If there's a wire
in sight, brown is always ground on German vehicles, you can splice a separate ground wire to the circuit board and splice it to any ground wire or use a nearby grounded bolt or nut. Hope it helps.
Happy New Year
Franasia is offline
post #9 of 9 (permalink) Old 12-15-2014, 10:46 PM
Date registered: Aug 2009
Vehicle: 2007 SL550, 1996 E300 Diesel, 1959 220SE, 1965 Unimog 404.115-Sold
Quoted: 11 Post(s)
Great information. After reading your post I found that the sheet metal on my housing was also burned through. I was able to clean it up with emery cloth and it is now working again. Thanks for the information.
2007 SL550
1996 E300 Diesel
1959 220SE Fuel Injected
compconsult is offline
turn signal light out on right outside mirror cktong W163 M-Class 8 11-17-2014 12:27 PM
How to replace turn signal light ? aj_sl500 R230 SL-Class 1 08-15-2009 12:35 AM
Turn signal problem........ nobrakes General Mercedes-Benz 6 08-02-2009 09:24 AM
SRS light and Turn Signal Horus R129 SL-Class 0 11-14-2006 10:57 AM
Clear Turn Signal Light Malone W124 E,CE,D,TD Class 1 09-01-2005 10:15 PM
