V belt completely shredded ... - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 12-13-2009, 10:28 PM Thread Starter
delikanli's Avatar
Vehicle: 1992 300CE, Engine M104, (2002 E320 4matic Wagon由etired)
As I was driving back with a full carload of folks from a holiday party, the smell of burnt rubber and loss of power steering caused me to stop right in front of the fire department. The vbelt had been making a bit of noise for a few days, but it now it was completely caput.
Since I could not quite drive it I had it towed to a service station.
How did I do? Should I have parked it somewhere and attempted to replace the belt myself? How difficult is it to replace the belt?
I have successfully replaced a belt on my washing machine. And this seems like a similar kind of deal. Any thoughts?
delikanli is offline
post #2 of 21 (permalink) Old 12-13-2009, 11:36 PM
Kajtek1's Avatar
Quoted: 1957 Post(s)
There is no V-belt on the car.
Replacing serpentine belt takes about 3 minutes the SECOND TIME but sounds like you have bad bearing somewhere?
Find the routing in the manual.
Kajtek1 is offline
post #3 of 21 (permalink) Old 12-14-2009, 04:41 AM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 18 Post(s)
Chances are you have a problem with a rotating accessory such as tensioner, idler pulley, etc. Before you put on a belt, rotate each one to make sure all of them rotate smoothly.
loubapache is offline
post #4 of 21 (permalink) Old 12-14-2009, 05:29 AM Thread Starter
delikanli's Avatar
serpentine belt
Yes. It's the serpentine belt. I have not replaced it ever. You are probably right. There must be another issue besides wear/tear on the rubber belt. In the case of my washing machine it was a small sock blocking the pulley system.
post #5 of 21 (permalink) Old 12-14-2009, 07:53 AM Thread Starter
delikanli's Avatar
So...I just went to the shop to take a look. The belt tensioner/pulley was jammed so that will be replaced. And the mechanic also recommended replacing the water pump. Of course I do not know if this is bolone or good advice. He said that it was moving a little bit and it should not. I checked it out and it did move a little bit. Supposedly the bearing inside is worn out and I should replace the whole thing.
post #6 of 21 (permalink) Old 12-14-2009, 07:59 AM
Kajtek1's Avatar
Bad pumps usually leak, but if it has noticeable play, that is not a good sign.
That job will cost you, so shop around for deal on parts.
I paid $80 for the belt at the dealer before. Water pumps run in high hundreds.
Kajtek1 is offline
post #7 of 21 (permalink) Old 12-14-2009, 09:39 AM Thread Starter
delikanli's Avatar
Hmm...Strange then. They quoted me around $500 for the water pump job. And another $450 for the belt + jammed pulley part replacement.
post #8 of 21 (permalink) Old 12-14-2009, 09:51 AM
Kajtek1's Avatar
That's the labor, or parts?
Water pump list for $408 and takes pretty long time to get to. There is a lot of aftermarket, or rebuild parts, so beware.
Kajtek1 is offline
post #9 of 21 (permalink) Old 12-14-2009, 10:13 AM Thread Starter
delikanli's Avatar
Thanks for the advice. I have no idea what kind of pump they will be putting in. Its a AAA facility. And the benz dealer is across the street. Maybe it is time to enroll in that Community College course. It is too late to save this repair, but I will try to do some other stuff like the heating issue, and brakes (I will still have to go to a shop I suppose).
post #10 of 21 (permalink) Old 12-19-2009, 02:42 PM
Date registered: Dec 2009
evening all.....first time to site and thought i would use your expertise to see if anyone can advise me....i have 99 ml320 qwhich i love to bits...she just sailed through another mot but today when driving home i could smell burning rubber but not that bad....i checked under bonnet and saw nothing so drove towards home.....as i was down the street i heard some strange noises and then loss of power steering and alternator battery light came on on dash...
i pulled car over and looked inside engine bay......the serpentine belt is off and the big main wheel (dont know the name) is all wobbly and actually looks like come off......the grooved wheel i mean....
so firstly what is the main large wheel.......can it be replaced or reattachd and is it hard to do....im pretty handy around the engine bay and car in general.....have changed brakes and pipes.....replaced sensors and so on...
i look forward to hearing from anyone who may have some answers...
all the best
gary
bullyuk is offline
Belt tensioner / Belt pulley info sarmstrong W210 E-Class 11 01-02-2009 02:43 PM
OT: The W123 people are completely, completely different... to loss W126 S,SE,SEC,SEL,SD,SDL Class 28 01-18-2008 06:09 PM
Converting lap belt to three point seat belt suttree G-Class 3 06-09-2007 10:34 AM
hit a shredded truck tire yesterday on I 95... adrose R170 SLK-Class 6 11-13-2004 05:47 AM
Voter registration cards allegedly shredded GeeS Off-Topic 4 10-14-2004 02:47 PM
