Magnet for oil pan, does it make sense? - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 12-04-2009, 04:16 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 18 Post(s)
With a rare earth, you can probably just put it on the bolt head and then use a deep socket to remove the bolt during oil change time. I think the rare earth should stay on due to its very strong magnetic field.
loubapache is offline
post #12 of 20 (permalink) Old 12-04-2009, 05:44 PM
Date registered: Sep 2008
Vehicle: 2002 E430 4-Matic
Quoted: 34 Post(s)
Just a thought....what is the risk of having an external magnet collect all the metallic debris and then for what ever reason....releasing everything into the oil pan as a single glob of metal, possibly held together by magnetism?
Figuero is offline
post #13 of 20 (permalink) Old 08-09-2017, 10:43 AM
Date registered: Aug 2017
Automatic Transmission Pan Black Hole Particle Pick Up Magnets - Super Strength
https://mercedessource.com/store/aut...super-strength
just came across this but not sure of availability in the UK, would it be worthwhile. considering it as just got ATF fluid/filter changed (w220 722.6)
any opinions?
w220ox is offline
post #14 of 20 (permalink) Old 08-10-2017, 02:51 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 298 Post(s)
Just a week ago I did a transmission pan drain and drop.
I fitted two additional magnets to the inside of the pan. The best magnets to use are Samarium Cobalt. These are very high temp. stable,and will maintain their strength at temps up to 300 degrees celcius or 572 degrees F. . (Neodymium magnets start to lose power at 80 degrees C.).
I don't see why you couldn't put one on the end of the engine sump bolt.
I got mine from Apex Magnets in USA,via ebay.
MAVA likes this.
Benzyle is offline
post #15 of 20 (permalink) Old 08-10-2017, 03:09 AM
panzernacker's Avatar
Date registered: May 2016
Vehicle: 1989 W124 260E Saloon. M103 lump.
Quoted: 318 Post(s)
You can fit magnets inside, out side, on the sump plug , in the sump plug, any place you think it will hold particals of metal .They all do the job they are put on there for . I only put them in to my engine sump drain plug at the moment . You will get a replacment with the magnet fitted inside the plug itself as you knpw. And i have sent for one that fits on top of the oil filter . But i have yet to fix one in to the gearbox [auto] . In all a good idea to catch those bits of metal that float around .
panzernacker is offline
post #16 of 20 (permalink) Old 08-10-2017, 07:49 AM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1233 Post(s)
I too have used Samarium in my Transmissions. I put like eight all around the pan.
On the engine drain bolt, my Ford Mustang has a bolt with a magnet on the end.
Martin
MAVA is offline
post #17 of 20 (permalink) Old 08-10-2017, 03:16 PM
Kajtek1's Avatar
Quoted: 1978 Post(s)
The W211 has factory magnet on the same transmission. It has shape of the ladder and fits between the pan ribs, so can't move around.
If you are really that concern about having magnet, get the right one.
Kajtek1 is offline
post #18 of 20 (permalink) Old 08-11-2017, 03:22 AM
Benzyle's Avatar
Quoted: 298 Post(s)
Unfortunately here in Australia the dealer quoted me $55 for one MB magnet.
Needless to say I declined and subsequently found six magnets for a little over half that much on ebay.
Benzyle is offline
post #19 of 20 (permalink) Old 08-11-2017, 07:10 AM
Kajtek1's Avatar
Do you have part # ?
For some reason MB parts are cheaper in USA than even in Germany.
With longer shopping list it might make sense to order at Husker, or whoever and pay not that big shipping.
Kajtek1 is offline
post #20 of 20 (permalink) Old 08-11-2017, 11:21 AM
Date registered: Aug 2011
Quoted: 10 Post(s)
I always thought those Filter Mag gizmos were pretty clever for engine oil, but they cost more than twice as much as I'm willing to pay. Keeping any captured metal particles inside the filter for easy removal is a great idea.
Taurine is offline
Mercedes Transmission Pan Magnet xvvvz W202 C-Class 2 08-03-2012 04:29 PM
Transmission Pan Magnet and Ignition Wire Clips SPVFD47 W210 E-Class 2 10-06-2008 02:26 PM
does this make ANY sense? dbs600 W140 S-Class 7 09-10-2008 10:52 PM
crossfire oil pan = e320 oil pan? (upper pan removal?) fastmayte W210 E-Class 4 06-28-2008 04:06 PM
Does this make sense, or the service dept. selling me snake oil? Murray von Kanada R170 SLK-Class 23 01-22-2002 06:48 PM
