Video Stickies - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 07-08-2009, 06:51 PM Thread Starter
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 18 Post(s)
Video Stickies
I started some compilations of video in the general info stickies. So far here are a few:
https://www.benzworld.org/forums/w210...ml#post3574488
https://www.benzworld.org/forums/w210...ml#post3580688
If you have links to some others, please post here.
loubapache is offline
post #2 of 14 (permalink) Old 09-20-2009, 08:13 AM Thread Starter
Quoted: 18 Post(s)
Video DIY: Rear Window Regulator Replacement
Thanks to faizalza for uploading these videos.
This post serves as a compilation and the permalink is added to the sticky.
Part 1
Part 2
Part 2.1
Part 2.2
Part 3
Other videos by faizalza
YouTube - faizalza's Channel
post #3 of 14 (permalink) Old 09-20-2009, 08:23 AM
Musikmann's Avatar
Quoted: 8 Post(s)
Wow loubapache!
This is a great idea and I just browsed through what you have found. It looks like a lot of useful information for all of us. Sorry but I don't have anything to add.
Thanks,
Musikmann
Musikmann is offline
post #4 of 14 (permalink) Old 09-20-2009, 08:25 AM Thread Starter
Quoted: 18 Post(s)
Originally Posted by Musikmann View Post
Wow loubapache!
Thanks,
Musikmann
A wheel washing video DIY? I know you like to keep the wheels clean from the OEM brake pad dust. You must have some secret to keep them clean.
I, along with many others, have gone to the low dust pads for about 15 years now.
post #5 of 14 (permalink) Old 09-20-2009, 10:00 AM
Musikmann's Avatar
Quoted: 8 Post(s)
Originally Posted by loubapache View Post
A wheel washing video DIY? I know you like to keep the wheels clean from the OEM brake pad dust. You must have some secret to keep them clean. I, along with many others, have gone to the low dust pads for about 15 years now.
Haha, no secret but I don't drive the car much, never brake hard, and wash them regularly. The main problem I have is the 11-spoke wheels. There are so many places for the dust to stick/hide and I haven't found an effective brush for some of the tight places. To get it all, I have to wipe around with a wet paper towel.
post #6 of 14 (permalink) Old 09-22-2009, 08:30 AM
faizalza's Avatar
Date registered: Sep 2005
Vehicle: W211 E200 Kompressor
Thanks guys for viewing my video. I will adding more such as replacing water pump, blinking 3rd LED brake light, removing dashboard, servicing duavalve, replacing belting, servicing DC motor for air con blower and radiator fan and many more.
Its difficult to DIY and capture video at the same time. Since my daughter is the cameraman, I need to check her availability.
Thanks again...
Cheers
faizalza
faizalza is offline
post #7 of 14 (permalink) Old 09-22-2009, 08:33 AM Thread Starter
Quoted: 18 Post(s)
Thanks again, faizalza, for posting.
Keep them coming.
post #8 of 14 (permalink) Old 09-22-2009, 09:33 AM
Olivier A's Avatar
Date registered: Jun 2008
Vehicle: E300TD 1997 W210 Running on WVO and a % of dino...
Well done Loubapache. Top sorting and posting
Olivier A is offline
post #9 of 14 (permalink) Old 09-22-2009, 09:35 AM Thread Starter
Quoted: 18 Post(s)
Thank faizalza.
I only compiled them.
post #10 of 14 (permalink) Old 12-13-2009, 06:44 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 10 Post(s)
Some Small But Possibly Necessary Additional Details
A Very complete set of videos - thank you
The water shield - that pink plastic film under the door panel should be carefully glued or taped carefully around the edges before replacing the panel.
This film keeps any water in the door from rain (or Malaysian monsoons) from getting past the door barrier and soaking the door panel.
My doors also have a small white plastic clip that needs to be coaxed up before the inside door release will let you pull out the cable hook for the hinge. His door did not seem to have that.
If you have an airbag in the door the plastic "SRS" emblem pry's out and there's another Philips screw underneath that too.
If you have an ambience light - the small bulb lighting the handle inside at night - you need to remove that by pushing it up carefully from the base. It just wedges into the plastic holder. The wire is small so extra care needs to be taken not to pull and break them.
I pushed the glass to the top (closed - sort of) from the inside before drilling out the rivets. It would be awful to scratch or break the glass. I use a piece of packing tape to tape it closed.
I also tape it closed after it breaks and before the ordered regulator shows up from my online order site. This keeps the car operable with a closed window in the interim.
mjhawkins2346 is offline
About those Stickies Digmenow R/C107 SL/SLC Class 53 06-08-2009 05:24 AM
Where are these DIY stickies? et1123 W124 E,CE,D,TD Class 1 12-02-2008 10:20 AM
No Stickies in OT edfreeman Off-Topic 30 04-14-2008 03:30 PM
TIP/DIY Stickies to be reworked soon.... Check Codes W210 E-Class 12 03-22-2008 10:53 PM
Poll:Too Many Stickies? Nutz 4 Benz W123 E,CE,D,CD,TD,TE Class 32 09-07-2006 06:20 PM
