DIY on W210 rear door lock actuator replacement? - Page 2 - Mercedes-Benz Forum
post #11 of 44 (permalink) Old 07-07-2009, 04:59 PM
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
iluvjesus is offline
post #12 of 44 (permalink) Old 07-07-2009, 05:05 PM
iluvjesus's Avatar
Vehicle: 210.065
Looks like you need to remove the molding as well, I would remove the molding instead of the door handle.
post #13 of 44 (permalink) Old 07-07-2009, 05:12 PM Thread Starter
Date registered: May 2008
Vehicle: 2002 E430 SE
I've gotten that far (pulling the panel). And, some of the screws in the diagram look different than my door. I took out a total of 5 screws to get the lock mechanism loose. #11 screw, there was 2 of those. And there was a screw that was in the bottom of the actuator that I removed too, which I dont see in the diagram.
The Moulding does not protrude inside the door, so I cant see why I'd want to remove it.
Red66gt is offline
post #14 of 44 (permalink) Old 07-07-2009, 05:16 PM
iluvjesus's Avatar
Vehicle: 210.065
Here is the link you can use to search the parts of your car.
??????? ????????? MB. ????? ??????.
As I said, you probably need to remove the molding, since you've got the parts, worth a try. If you don't want to touch the moulding, you can always ask any mechanic to do it for you and you provide the parts. They should not charge you more than an hour or two for labor.
post #15 of 44 (permalink) Old 07-07-2009, 05:36 PM Thread Starter
Appreciate the link. And yes the hardware on my door and yours are different. Here's mine:
I really need more info than this as I dont know what needs to come out and what doesnt. I have the WIS software on my computer, but it stopped working....it will only show German language.....
Red66gt is offline
post #16 of 44 (permalink) Old 07-07-2009, 06:18 PM
iluvjesus's Avatar
Vehicle: 210.065
I think only the numbers differ.
post #17 of 44 (permalink) Old 07-08-2009, 02:08 PM Thread Starter
Anyone else?
Red66gt is offline
post #18 of 44 (permalink) Old 07-21-2009, 11:04 PM Thread Starter
DIY Rear Door Lock Actuator w/pics
Mods, please add this to the correct sticky if you see fit. I finally broke down and bought the WIS softare in order to get the proper way to replace my actuator.
First, remove the door panel. (write up on that is already on this site).
Next you need to remove the door handle. First you need to pull the door seal out right around the door latch and there is a hidden allen screw behind it. It is 4mm (WIS software said 3mm, but mine was 4mm). Unscrew this screw 5 complete turns. Do not unscrew it all the way out as it will fall into the door and you'll need to fish it out.
Yellow arrow shows the allen screw. White arrow shows the door latch for reference:
Once you loosen this screw you can remove the door handle. From the outside of the door, pry the piece towards the back of the car (the part of the outer handle that does not move - yellow arrow).
Be careful not to scratch your paint. This part took me a long time and I tried from both inside the door and outside. Eventually I just hit it right and it fell out. Once this piece is out you simple slide the rest of the handle towards the rear of the car and it will come right out (the white arrow). Remove the rubber seals as well. This is what you will have at this point.
Now you need to remove the part of the door handle that is inside the door. In the last pic above, just loosen the 3 screws (dont take them all the way out) and then you can move the assembly towards the front of the car and remove it from the inside of the door.
Now it's time to finally remove the door latch/actuator assembly. Below is a pic of the latch/actuator assembly in the door. Remove all of the torx screws at the red arrows. Remove the air line at the yellow arrow (carefully!!! you dont want to break the plastic piece that holds this on...work it off carefully). The green arrow shows the lock rod that needs to be pulled out of the assembly as well. I did leave the rod on the door, I just popped it out at the green arrow. Once you have these all out, you can now work the entire assembly out of the door. (note: the very lowest red arrow in the pic you do not need to remove until you get the assembly out of the door....I removed it and it would be easier to remove it once the assembly is out).
Below is a pic of the assembly removed from the door. Pop the top of the actuator out of the metal piece (yellow arrow)...I just used needle nose pliers and broke the plastic, and remove the screw from the bottom of it (red arrow). You can slide the actuator out.
Now....to re-install in the opposite order!
Hope this helps.
Red66gt is offline
post #19 of 44 (permalink) Old 07-22-2009, 04:53 AM
iluvjesus's Avatar
Vehicle: 210.065
Thank you very much Red, great write up, glad that your problem is solved too.
By the way, how do you get the "benzworld.org" on the lower right hand corner of your photos?
post #20 of 44 (permalink) Old 07-22-2009, 05:35 AM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 18 Post(s)
Thanks, Red66gt, for the great writeup.
It has been added to the stickies.
loubapache is offline
DOOR LOCK ACTUATOR verdejor Vintage Mercedes-Benz 0 02-05-2009 10:10 AM
FS: Door lock actuator MLMoose W163 M-Class 3 08-02-2008 08:50 PM
Front door lock actuator 4484 W124 E,CE,D,TD Class 3 10-13-2007 06:40 PM
Fuel Door Lock Actuator cal45fan W163 M-Class 6 12-05-2006 02:41 AM
460 door lock actuator FS termite G-Class 4 10-20-2005 07:19 AM
