Side View Mirrors - Symptoms & Several DIY Fixes - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 05-30-2009, 12:51 PM Thread Starter
MarkZ's Avatar
Date registered: May 2009
Vehicle: 1997 E420
I just bought a beautiful '97 E420, but with big mirror problems on both sides. The driver's side was really screwed up by the previous owner trying to replace the glass with an amber lens, and I found cracked key plastic components inside. I also troubleshot and repaired the mirror adjustment switch. Before you buy the whole window / mirror switch module, please know that you CAN fix this component! Attached is a detailed doc file, pics and videos. This fix addresses the following symptoms:
1. Driver's mirror would work in all directions except one.
2. Driver's side mirror seemed a bit "floppy" vertically.
3. Passenger side mirror did not work at all.
4. A broken tension spring that had popped.
I hope this can help someone. I saved over $500 in OEM parts! Good luck, Mark in FL
Videos for removing mirror covers & assembly from car:
YouTube - MB W210 mirror cover
YouTube - Mercedes C W202 - Smontaggio specchio retrovisore destro
ID:	241554   Click image for larger version
ID:	241555   Click image for larger version
ID:	241556   Click image for larger version
ID:	241557   Click image for larger version
ID:	241559   Click image for larger version
ID:	241560   Click image for larger version
ID:	241561   Click image for larger version
1997 E420
88k miles
MarkZ is offline
post #2 of 19 (permalink) Old 05-31-2009, 04:51 AM
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
Thank you Mark, the videos are great. May I suggest you to add some annotation on the pictures so that we know what we are doing?
iluv
JESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline
post #3 of 19 (permalink) Old 05-31-2009, 06:14 PM Thread Starter
MarkZ's Avatar
Vehicle: 1997 E420
I'll try to repost those pics with some annotation. I was late for a bike ride - it was a beautiful day at the time. If there are any specific questions, please ask and I'll try to help.
1997 E420
88k miles
MarkZ is offline
post #4 of 19 (permalink) Old 06-01-2009, 05:31 PM
bamabytes's Avatar
Date registered: Mar 2007
Vehicle: 2008 AMG E63 89,000 Miles
thank you! i have a 97 e320 same color as your and my passenger mirror needs replaced and is also 'floppy'. thanks so much!
bamabytes is offline
post #5 of 19 (permalink) Old 06-02-2009, 06:59 AM
fju2112's Avatar
Date registered: Nov 2005
Vehicle: 2014 E350 4Matic sedan, 68K miles (purchased Jan 2017)
Quoted: 56 Post(s)
hi mark - my remote trunk release switch on that same switch assembly won't work. the light still lights up when the trunk is up, but i've checked the PSE hoses under the seat, etc., and all that seems to be fitting just fine. So do you know how I can troubleshoot and fix that short of replacing it with a used part? Best priceI've found at salvage yards per ohlord is $175, so don't wanna pay that just to fix one darn switch, particularly the trunk!
Current: 2014 E350 4Matic sport sedan, 62K miles, black/black; P01 Premium Pkg/Keyless-Go/Power Trunklid/pano roof/heated steering wheel/lighting package/driver assist. Purchased 1/2/17; Delivered 1/4/17.
Sold but not forgotten: 2002 E320 4matic sedan, black on beige ("sport" package - bird's eye maple trim, 17" sport rims), 108K miles upon sale.
RIP: 2000 E430 4Matic fully loaded - totaled 12/9/2006
fju2112 is offline
post #6 of 19 (permalink) Old 06-13-2009, 08:57 AM Thread Starter
MarkZ's Avatar
Vehicle: 1997 E420
Hi fju2112-
I'm not familiar with the console switches on the face lifted W210's. As you can see, the trunk release on the '97 is separate from that switch cluster for the windows & mirrors pictured above. But I believe the removal of the wood trimmed switch plate cover is the same on all W210's. In my experience, switches, whether electrical or audio, don't "break" in a mechanical sense, as much as they just get "dirty." So see if you can remove that switch and carefully unsnap it apart to clean the contacts inside. It's usually dirt, corrosion or a copper contact that just needs a little "bend" to get things back to working order. With switches that are snapped together, its always best to have super glue ready to put them back together.
Mark in FL
1997 E420
88k miles
MarkZ is offline
post #7 of 19 (permalink) Old 06-13-2009, 10:09 AM
fju2112's Avatar
Quoted: 56 Post(s)
hey mark - that's actually a great idea...given it doesn't appear to be a PSE hose issue and the light still lights up when the trunk is open, that's likely what it is. I'll get on that; I have removed the switch panel before to get the part #, but didn't think to clean it - should have! Thank you!
fju2112 is offline
post #8 of 19 (permalink) Old 10-06-2009, 01:49 AM
Date registered: Sep 2009
Vehicle: '82 300DT 106k, '83 300DT 311k, '98 E300TD 135k - All Great Cars
markz, thx for the help. my wife's right-side mirror was floppy. i removed the housing and tethered the spring w/ a piece of copper wire essentially where it hooked before. saved me a bundle!
jmcqueen is offline
post #9 of 19 (permalink) Old 09-24-2010, 09:13 PM
GDRAPER's Avatar
Date registered: Jun 2009
Vehicle: 98' E320, 11' E350
w210 mirror fix
Great writeup. My mirrors became loose after some autobody work. They must have tried to remove the covers for a paint touch up job and brooke the spring hooks. I used zip ties to secure my springs.
ID:	333168   Click image for larger version
GDRAPER is offline
post #10 of 19 (permalink) Old 09-25-2010, 03:20 PM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2013 GLK350, 2007 S550, 2002 S430, 1998 ML320. Deceased - 1974 240D, 1992 400E, 1997 E420
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 94 Post(s)
Had FMS (Floppy Mirror Syndrome) after body work on door last year. The shop had managed to break the spring hook.
The fix - Removed the spring completely, and softened the metal with a torch to red hot, then quickly bent in a new hook with large needle nosed pliers. Took about three heat and bend cycles to complete the bend. After cooling, used zip tie like shown above because the spring was shorter.
atmsmshr is offline
Side view Mirrors sanmanbx3 W163 M-Class 3 03-14-2006 05:43 PM
Side view mirrors dylanhappy G-Class 0 01-27-2006 07:37 PM
SIDE VIEW MIRRORS SL FIZZLE W201 190-Class 1 03-30-2005 06:49 PM
Side View Mirrors ///S320 W140 S-Class 6 10-30-2003 01:02 AM
SIDE VIEW MIRRORS!!! siksclass W140 S-Class 2 08-29-2002 07:51 PM
