ATF in Transmission Control Module: 99 E 320 - Page 17 - Mercedes-Benz Forum
post #161 of 167 (permalink) Old 04-20-2014, 10:15 AM
Date registered: Sep 2008
Vehicle: 2006 E 350, 2007 c 280 4-matic
I know this is an old thread, but is the 2006 E 350 the same transmission? I have a 2006 E 350 non-4 matic, with two codes P2767 AND P2768 (Input/Turbine speed sensor "B" no signal and Input/Turbine speed sensor "B" circuit intermittent). So, if same or similar, do I just ned to replace the sped sensors only.......and of course, new filter, oil. etc.?
dcmsm is offline
post #162 of 167 (permalink) Old 04-20-2014, 10:34 AM
Date registered: Jun 2011
Vehicle: 2001 E320 RWD- 2011 E350 4M
Quoted: 17 Post(s)
As far as I know, If your car was a 4Matic then you`d have the same transmission, 5 speed 722.6 but you have a rear wheel drive car fitted with 7 speed 722.9 transmission.
I can`t really answer your other questions since I don`t know much about 722.9 transmissions but still it should not be too far off from the 5 speed 722.6.
01blackhawk is offline
post #163 of 167 (permalink) Old 04-20-2014, 11:11 AM
Outstanding Contributor Always Remembered RIP
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 150 Post(s)
Looks like the speed sensor plate gone down and so common, not that expensive and you get a fluid and filter change at the same time.
television is offline
post #164 of 167 (permalink) Old 11-14-2014, 08:28 PM
Date registered: Nov 2014
Smile 2006 Mercedes Benz C230 Sport 2.5 V6 speed sensor failure. P2767
Hi everybody.
I got stuck in 2nd gear (limp mode) also got Check Engine lite ON. Scanned the system and got P2767 speed sensor no signal. Was reading a lot of forums and decided to replace the speed sensor, which is Conductor Plate.
I just started to replacing conductor plate on my 2006 MBZ C230 Sport 2.5 V6. I found out that my MBZ doesn't have transmission fill port. So, anyway I have to fix my MBZ myself. I don'n want to spend $xxxx... Will try to pump fluid after repairing, through the drain plug. So, I drained about 7 US quarters of fluid, simply removed the pan. Then I removed the valve body and then removed the conductor plate. So, the first valve and the fifth was very dirty. The fluid also very dirty (looks like I drained engine oil after 7k miles driving). My MBZ has only 54k miles on it. That's all for now, I will post updates as soon as I will get farther...
srglavor is offline
post #165 of 167 (permalink) Old 02-28-2018, 05:31 PM
Date registered: Dec 2009
Vehicle: 2002 E320 4Matic W210 w/ 230k as of 03/15/2018
Quoted: 17 Post(s)
What kind of bin is the valve body sitting in? I want one
See post #56 of this thread for the pic.
Originally Posted by loubapache View Post
Everyone has a happy ending.
Op (Sri) had his conductor plate replaced by an Indie and all is well.
I replaced the conductor plate by myself today and all is also well. Here is a DIY writeup in PDF format (with photos) and also a picture of the valve body to get you in the mood reading the DIY article. It looks a little like open heart surgery, LOL.
We can happily close this thread now.
Edit: I re-uploaded the DPF file because I found a few typos.
Sibarks is offline
post #166 of 167 (permalink) Old 07-08-2019, 08:33 AM
Date registered: Jul 2019
on my 98 mercedes e320 4matic its not shifting from first gear the rpm just keep going higher does anyone know why?
thanks kenny
kennethbrock1 is offline
post #167 of 167 (permalink) Old 07-08-2019, 11:36 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1191 Post(s)
Send a message via Skype™ to mrboca
thanks kenny
You mean when you shift the gear in Drive from Park or Neutral ?
How about Reverse ?
No-shift, right from the start, or after driving for a while ?
mrboca is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
C230 Transmission control module question Behind Blue Eyes W202 C-Class 16 09-28-2015 11:09 AM
Help!!! Transmission Control Module eapen W210 E50 AMG, E55 AMG 2 05-01-2009 12:02 PM
E420 - Transmission Control Module Failure... chrisdpham W124 E,CE,D,TD Class 9 04-05-2008 02:37 AM
Transmission Control Module Change out baisdelr W163 M-Class 1 02-12-2008 03:40 PM
Transmission Electronic Control Module Tacjam W210 E50 AMG, E55 AMG 4 05-04-2006 10:23 PM
