Hypothetically speaking... - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 03-20-2009, 06:13 PM Thread Starter
Forum Administrator
RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2005 S500 116K
Quoted: 2233 Post(s)
...you're in a local junkyard where you pay a dollar to go through the rows and pull your own parts (yes, such places still exist) and you come across a 210 exactly like your own. You don't really need anything but you have just enough time before the place closes to pull ONE part (or set) and you're going out of town for a month tomorrow so the car will be picked clean upon your return.
The prices are real.
Crazy Rays Used Auto Parts
What part do you go for?
(Second figure is core charge)
ABS Module ...................... 45.00......... 5.00
A/C Compressor..................27.13.........4.00
A/C Condenser....................12.15........... 2.00
A/C Evaporator.................... 12.15........... 2.00
A/C Line............................ 10.37
Accelerator Cable................ 6.60
Air Bag (restraints) ...............55.66
Air Cleaner.............................15.09
Air Flow Meter Domestic ............25.47
Air Flow Meter Foreign ...........40.56
Air Ride Compressor .............. 20.75
A-Frame Control Arm...............4.15
Alternator ............................ 15.75........... 5.00
Antenna............................... 1.88
Antenna "Power"..................... 12.26
Anti-Freeze Bottle................... 9.43
Axle (Straight) ....................... 16.03
Axle (C.V. Type)...................... 20.47........... 5.00
Backing Plate .......................8.49
Battery................................ 18.52........... 6.00
Bed Liner ............................ 35.84
Bell Housing .......................... 10.09........... 5.00
Brackets (miscellaneous)......... 5.66 & up
Brake Cable .......................... 10.37
Brake Drum............................ 10.37
Brake Drum & Hub .................. 15.09
Brake Proportioning Valve ........... 6.60
Bumper....................................42.39... ....1.00
Bumper Shock or Bracket........... 6.60
Caliper .................................. 13.21
Cam Shaft............................... 15.09
Carburetor/TBI unit ................... 30.07........... 2.00
Carpet ..................................... 18.86
Center Post............................... 25.47
Climate Control...........................20.75
Clock........................................ 8.49
Coil Ignition................................ 6.60
Coil Pack (Ignitor)........................ 22.64
Coil Spring ................................. 8.49
Combination Switch...................... 20.75
Consoles ................................... 18.86
Convertible Top ...........................50.00
Cowl Screen.................................12.26
Crank Shaft...................................25.19..... ...... 5.00
Cruise Control Transducer ................ 8.49
Cylinder Head (No Cam).................... 40.45......... 2.00
Dash Pad ....................................20.75
Deck Lid ...................................... 40.45........... 2.00
Distributor..................................... 20.64........... 2.00
Distributor Cap............................ 4.71
Dip Stick.................................... .94
Dip Stick's/Tube"....................... 3.83
Doors ................................. ... 50.00
Door Handle (inside).................... 5.66
Door Handle (outside)................... 8.49
Door Latch................................... 8.49
Door Panel................................... 12.26
Door Motor.................................. 13.21
Drag Link ..................................... 12.26
Drive Shaft.................................... 20.64........... 2.00
ECM. ...................................... 25.35........... 2.00
E.G.R. Valve ............................. 5.66
Electric Master Switch............... 12.26
Emergency Brake Ratchet .......... 10.37
Engine No Accessories ............... 185.00...........15.00
Engine Block (No Heads) ..............100.00
Exhaust Manifold ..........................15.03........... 1.00
Exhaust Pipe.............................6.60
Exhaust Y-Pipe or Flex Pipe............12.26
Electric Cooling Fan ......................15.92........... 2.00
Fan Clutch Assembly.................... 10.26........... 2.00
Fan Shroud................................ 10.37
Fender No Accessories .................. 35.73........... 2.00
Filler Panel .................................10.37
Flywheel...................................... 5.66
Fuel Injector (each)...................... 8.49
Fuel Injector Unit.........................45.28
Fuel Pump (Electric) ....................20.75
Fuel Rail (bare)............................15.09
Fuel Rail (complete)....................45.28
Fuel Tank Sending Unit.................10.37
Fuse Box .................................. 15.09
Gas Tank .................................. 25.47
Gauge ......................................... 8.49 and up
Glove Box Door.......................... 10.37
Grill "No Accessories" .................. 20.75
Harmonic Balancer ...................15.03 ........... 1.00
Hatch Cover............................. 12.26
Hatch—Hood, Trunk, Pistons ........ 6.60
Header Panel Bare ...................... 40.56
Headlight Bezel........................... 8.49
Headlight..................................... 22.64
Headlight with parking light..............30.19
Headlight Motor.......................... 15.92 ...........2.00
Headlight Switch ..........................12.26
Head Liner...................................15.09
Heater Control............................. 15.09
Heater Core.................................. 12.15 ...........2.00
Heater Motor................................12.15 ........... 2.00
Hinge (Door or Hood) .......................6.60
Hood ..............................................42.4 5
Horn ......................................... 2.83
Horn Pad .................................... 6.60
Hubcap .......................................6.60
Idler Pulley...................................10.37
Idle Speed Control Sensor ..............12.26
Ignition Module...............................12.26
Ignition Switch..............................15.09
Inner Fender Well............................12.26
Instrument Cluster............................25.47
Intake Hose .................................... 8.49
Intake Manifold ................................25.47
Jacks ...........................................5.66
Leaf Spring ....................................13.21
Lock Actuator ................................ 10.37
Marker Light....................................5.66
Master Cylinder................................ 13.21
Map Sensor...................................... 12.26
Mirror Outside ...................................14.15
Mirror Inside ......................................8.49
Motor Mount......................................10.37
Molding Rocker & Door..........................5.66 and up
Muffler .............................................12.26
Oil Pan..............................................1 9.81
Parking Light.......................................9.43
Piston& Rod...................................... 10.26 ...........2.00
Power Brake Booster ......................... 15.92 ........... 2.00
Power Steering Pressure Hose .............. 6.60
Power Steering Pump .........................14.09 ...........1.00
Quarter Panel.....................................45.29
Quarter Panel Ext.................................15.09
Radiator ............................................35.56. .......... 5.00
Radiator Core Support No Acc............... 35.73 ...........2.00
Radio w/Cassette .............................. 19.81
Radio w/CD........................................ 39.62
Rear End Assm. (car or truck).............65.09
Rear Hatch Assm. Car......................... 50.00 ...........2.00
Rear Hatch Assm. Van or APV................ 64.98 ...........2.00
Rocker ..............................................25.4 7
Roof "Rack"........................................ 15.09 & up
Roof "Sun" ......................................... 25.47
Rotor............................................. .....12.26
Rubber Nose (No Lights or grill) .................65.09
Running Boards ....................................20.75
Seal—Window/Door ............................... 8.49
Sealed Beam.........................................94
Seats- NO MOTOR-CONSOLE-ARM REST
Seat Front or Rear Car .....................30.19
Seat Van or SUV (Front) .....................30.19
Seat Van or SUV (Rear) ......................40.56
Seat Belt ..............................................8.49
Seats — Front or Rear Truck...............40.56
Seat Motor........................................ 10.37
Seat Track........................................ 8.49
Sensors (relay) ............................... 5.66 & up
Shifter "Assembly" ................................ 15.09
Shifter Cable.................................. 6.60
Shock ........................................ 6.60
Slave Cyl Clutch ..................................6.54........... 1.00
Sliding Door ................................ 65.09
Smog Pump ............................... 8.37........... 2.00
Speaker ................................... 6.60
Spindle ..................................... 16.92.......1.00
Speedometer Cable....................... 6.60
Spoiler (rear) ..................................25.47 & up
Starter .................................... 14.92...........3.00
Steering Column................................. 40.56
Steering Wheel (No horn pad) ............ 12.26
Steering Gear Box .............................. 25.47
Steering Rack&Pinion.......................... 25.19........... 5.00
Steering Sector Shaft......................... 10.37
Strut............................................. .. 17.86 ........... 1.00
Strut & Spindle Assembly .................... 33.84........... 2.00
Sub Frame .......................................... 36.79 and up
Sun Visor ............................................ 6.60
Super Charger..................................... 75.47
Suspension Air Bags............................... 25.47
Sway Bar ........................................... 15.09
Tail Gate ......................................... 30.07
Tail Gate Motor................................... 13.15
Tail Light .......................................... 22.64
Thermostat Housing............................. 8.49
Throttle Position Sensor........................ 12.26
Tie Rod ............................................. 8.49
Timing Chain Cover................................ 15.09
Timing Gear........................................... 6.60
Tire .... 13" - 9.43, 14"-12.26, 15" -15.09, 16" - 20.75
Torque Converter............................... 15.92 ........... 2.00
Trailer Hitch.............................. 20.75
Transfer Case ............................... 60.37
Transmissions .......................... 90.00..............10.00
Transmission Crossmember.......... 15.09
Trim Panel ................................ 8.49 & up
Truck Beds and Cabs .................. SEE SALESMAN
TruckCaps ................ ................. 50.00 & up
Trunk Pull Down............................ 15.09
Turbo lntercooler............................ 25.47
Turbo Unit...................................... 45.00........... 5.00
Turn Signal Switch .,..................... 12.26
Vacuum Canister............................. 10.37
Valance ......................................... 15.09
Valve Cover....................................15.09
Window Regulator (no motor)................... 10.37
Water Pump ........................................10.32..... ...... 1.00
Wheel ..............................................12.2 1............1.00
Wheel "Aluminum"................... 30.79.................5.00
Wheel "Rally-Styled"........................... 20.75
Windshield "Prepaid" (removed by Crazy Ray s) 60.37 and up
Windshield Washer Pump ................ 4.71
Windshield Wiper Arm .....................5.66
Windshield Wiper Trans ..................12.26
Windshield Wiper Motor....................12.15.......... 2.00
Windshield Wiper Switch............. 12.26
Window Side ............................... 22.64
Window Back .............................. 35.84
Wiring Harness ............................ 5.66 a foot
Yoke "Rear End" "Drive Shaft".............. 12.26
Quis custodiet ipsos custodes?
Digmenow is offline
post #2 of 16 (permalink) Old 03-20-2009, 06:16 PM Thread Starter
Forum Administrator
Digmenow's Avatar
Personally, I'm torn between these two...
I guess that 'strut' would be what they'd call the rear shocks on the wagon. $450 ea from most parts places. brand new.
The driver's mirror alone approaches $400 with all the parts.
Digmenow is offline
post #3 of 16 (permalink) Old 03-20-2009, 06:19 PM Thread Starter
Forum Administrator
Digmenow's Avatar
OTOH...a set of 4 AMG monoblocks for $120?
Digmenow is offline
post #4 of 16 (permalink) Old 03-20-2009, 09:58 PM
Date registered: Jan 2008
Vehicle: W210 1996 E320 Smoke Silver. [W124 1990 300CE Artic White - Sold].
wish I were there
W210 1996 E320 Exterior Smoke Silver, Interior Mushroom, 159,999 miles as of 09/09/09, 170K as of 02/01/2011.
texholdem is offline
post #5 of 16 (permalink) Old 03-20-2009, 10:05 PM
Kajtek1's Avatar
Quoted: 1935 Post(s)
I used to be frequent visitor to "The biggest junkyard in the World" located in Hayward CA.
That thing was really exiting when I drove VW on older Mercedes.
Transmission for $60, alternator for $20 not to mention that $2 entry fee "covered" whatever you could fit in your pockets. Still have like 50 spare light bulbs.
Unfortunately the discount junkyard doesn't carry W210 yet, because those go to the dismantlers who charge for used parts 50% of dealers prices in the area, what quite often is the Duval's price for new stuff.
Kajtek1 is offline
post #6 of 16 (permalink) Old 03-21-2009, 11:09 AM
Date registered: Nov 2008
Vehicle: 96 E320, 98 SVT Cobra, 74 TR6, 74 MGB-GT
Which Crazy Ray's location was it in. I need a few things.
deadernie is offline
post #7 of 16 (permalink) Old 03-21-2009, 08:55 PM Thread Starter
Forum Administrator
Digmenow's Avatar
I was speaking hypothetically, Ernie. Just looking for some insight on what's valuable on this car.
Digmenow is offline
post #8 of 16 (permalink) Old 03-22-2009, 08:12 AM
Big"D"inTheMB's Avatar
Date registered: Jun 2007
Vehicle: 2005 C240-Retired
Electronic or metal ?????????????
Mercedes Benz, enough said.
Big"D"inTheMB is offline
post #9 of 16 (permalink) Old 03-22-2009, 05:28 PM Thread Starter
Forum Administrator
Digmenow's Avatar
In my experience there, it doesn't matter. If it fits the general description, that's the price.
Digmenow is offline
post #10 of 16 (permalink) Old 03-22-2009, 08:21 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If I were you I'd remove anything easily removable (coils, MAF, airbox, alternator, etc.) and sell it here or on ebay. $6.60 for a COIL? Wow. And no core on it.
I guess there has to be some compensation for living that close to crazyville.
Take care and enjoy the ride,
Greg
Check Codes is offline
Speaking of a sunroof... da_guitarist C208/A208 CLK-Class 10 08-01-2008 07:41 AM
Hypothetically....of course nobby R/C107 SL/SLC Class 13 11-06-2006 01:45 PM
Speaking of Independants blabad W210 E-Class 0 10-22-2006 01:42 PM
Speaking of Dashes proudhon W126 S,SE,SEC,SEL,SD,SDL Class 2 05-15-2006 02:59 PM
Speaking to GPS Scoundrl W211 E-Class 3 12-28-2004 06:22 AM
