DIY Pictorial Oil Change - V6 - Page 24 - Mercedes-Benz Forum
post #231 of 244 (permalink) Old 10-31-2017, 10:08 AM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
Quoted: 478 Post(s)
Amazon has the Genuine Fleece filter for $15 and the Mann OEM for $12 which I guess will be far better than the Fram filter.
https://www.amazon.com/Mercedes-Benz...R4XQHBF4VPM03Y
https://www.amazon.com/Mercedes-Benz.../dp/B00DHQYZPU
hamada128 is offline
post #232 of 244 (permalink) Old 10-31-2017, 12:26 PM
Date registered: Aug 2017
Vehicle: 99 E320 wagon 4matic
Quoted: 16 Post(s)
how do you know how far down the dipstick hole to put the hose
luckyinpa is offline
post #233 of 244 (permalink) Old 10-31-2017, 12:33 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 770 Post(s)
When you bottom out. (huehuehue -- sorry I couldn't resist that joke).
No, really. You bottom out. Shove it in until it doesn't go anymore.
Ok, ok, I'm done.
Deplore is offline
post #234 of 244 (permalink) Old 10-31-2017, 12:35 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1191 Post(s)
Send a message via Skype™ to mrboca
It seems cheaper in ebay. The markup at the stores is ridiculous.
https://www.ebay.com/itm/MANN-FILTER....c100010.m2109
I actually use a $6 fleece filter with good results.
You insert the inlet hose till it hits the bottom.
mrboca is online now
post #235 of 244 (permalink) Old 10-31-2017, 01:21 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
Saw this oil change kit on FCP Euro. Includes 8L of a Fuchs Pentosin 5W40 synthetic, Mann filter and even a washer for the drain plug for $62.99 incl free shipping. They also have Genuine MB and another oil brand (Rowe) but it costs more and not one I have heard of!
The Pentosin oil is Pento High Performance II and meets MB spec 229.51. FCP says in one place that it does and another that it does not fit my 98 W210 E320! Bevo 223.2 is supposed to tell us which oil for which engine, but doesn't seem to have older models.
They also have a kit with Genuine MB 229.5 oil and filter for $71.99.
https://www.fcpeuro.com/products/mer...ercedes-515700
Doesn't help us in Canada, but may be worth ordering when I visit USA?
In Canada, Mobil 1 0W40 costs C$50/4.4L at Walmart! In USA US$25.47 for 5qts (4.7L) I have in past bought 2 jugs in USA plus a filter here - Total about same as FCPs Pentosin.
MBGraham is online now
post #236 of 244 (permalink) Old 10-31-2017, 01:48 PM
Kajtek1's Avatar
Quoted: 2003 Post(s)
WOW. I tough only Scotch is so much more expensive in Canada
When shopping for parts - bare in mind that when internet supplier do have smaller markups, they also have to add shipping (this way, or the other).
When I was buying MB coolant, I check trusty autohousaz and local dealer come cheaper when I ask for discount (although I had to drive for it).
One more time, when extracting the oil, try to use dipstick tube as it will speed up the flow comparing to small hose stick inside.
Will probably pick up more as well.
Kajtek1 is online now
post #237 of 244 (permalink) Old 10-31-2017, 04:32 PM
MBGraham's Avatar
Quoted: 20 Post(s)
Kajtek,
Right! - I use biggest tube on my Mityvac extracter to dipstick tube where bung seals it. Quickly empties oil!
BTW, Those FCP oil kit prices included free shipping. For coolant, I just pick up Zerex G05 at NAPA - same as MB coolant used originally on W210. Cheap too.
post #238 of 244 (permalink) Old 10-31-2017, 06:13 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 282 Post(s)
has anyone used the topside vac pump and gotten good results? gotta admit id enjoy not jacking up my cars
also i realize theres a 25 torque on the oil cap but would it really be that bad to just tighten then use this to snug it up?
By the way you don't need to jack up the car to change the oil. You should be able to reach, by just laying down in front of the bumper and reaching back. Even on the E55 which is slightly lower to the ground, you don't have to jack it up.
illstplaya is offline
post #239 of 244 (permalink) Old 10-31-2017, 07:33 PM
Date registered: Sep 2013
Vehicle: 2006 S430, 1998 E430 Sport Black/Black Parting Out
Quoted: 18 Post(s)
Just get a mityvac, pump it 10 times and sit back and relax.
Don't forget to remove the filter so that you get everything from the filter housing.
Nice write-up though!
hamada128 likes this.
Alexander.Luthor is offline
post #240 of 244 (permalink) Old 11-01-2017, 07:12 AM
MBGraham's Avatar
Quoted: 20 Post(s)
I have that same unit. I disconnect the small tube from the rubber bung, then push the bung into the dipstick tube. As Kajtek mentioned earlier, much quicker removal of oil. But I have also done it with small tube, but oil needs to be warm.
DIY pictorial window regulator replacement ashman78 W210 E-Class 273 04-11-2015 01:22 PM
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 02:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK-Class 27 08-05-2008 07:58 PM
Hello! and interest in pictorial DIY for window regulator? ashman78 W210 E-Class 5 08-31-2005 07:00 AM
