Accelerator cable snapped! - Mercedes-Benz Forum
post #1 of 41 (permalink) Old 12-29-2004, 12:23 PM Thread Starter
Date registered: Mar 2004
Vehicle: E 430 4Matic
So I'm driving my 2001 E430 4matic to work yesterday and stop at a light. Step on the gas when it turns green and the gas pedal drops to the floor and I go nowhere. I idle over to the side of the road and pop the hood.
Taking a closer look, I notice the accelerator cable has broken from inside the connecting pivot. I've never heard of this happening on any car before. It wasn't rotted or anything, just cleanly snapped from inside that pivot point.
Has anyone else had this happen? Luckily its only $30 to replace the cable and pivot so it isn't that big of a deal, just extemely annoying [:(!].
-Mike D.
MaxPower169 is offline
post #2 of 41 (permalink) Old 12-29-2004, 06:47 PM
harb's Avatar
Date registered: Nov 2004
Vehicle: 2000 E320
RE: Accelerator cable snapped!
Can't help but to ask you: How hard and fast did you press on that pedal?! Just kidding - strange indeed. I would be very curious to find out if anyone has experienced something like this before.
Tony Harb
2000 E320
1990 300E
1986 380SE
1982 280SE
1977 280S
harb is offline
post #3 of 41 (permalink) Old 08-28-2005, 10:31 AM
Date registered: Aug 2005
Hey Tony and Mike,
Yes, mine just snapped yesterday... Fortunately I was already on the highway and had enough momentum to exit safely. I haven't seen any other posts about this, but it is a little ironic that of the two posts I have an E430 4Matic (2002) as well!
Stacey
YSLE430 is offline
post #4 of 41 (permalink) Old 08-29-2005, 01:27 PM Thread Starter
Interesting. I wonder if the accelerator cable pivot is poorly constructed or just weakens over time. I live near Boston so the change in temperature may have something to do with it as well. I guess we'll never know.
-Mike D.
post #5 of 41 (permalink) Old 08-31-2005, 06:57 AM
Vehicle: 2008 BMW 528i,1999 Lexus 400LS, 2014 e250 BlueTec
Quoted: 6 Post(s)
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Unless there was a kink in the cable, I don't see how cable could break off like that!
Raylee177 is offline
post #6 of 41 (permalink) Old 03-16-2006, 07:06 PM
Date registered: Mar 2006
Vehicle: 2002 E430 4 Matic
My accelerator cable snapped last year. I was turning left into a highway onramp. The left turn lane was 2 cars wide and there was a guy in a souped up 4 banger giving me the look on the other lane. I was going to smoke him. As soon as I had the nose pointed straight, I floored it hard then the cable snapped. The old lady in the minivan behind blew her horn in frustration at my slow pace. It was quite embarasing. Luckily, it was on a downgrade so I was able to coast to the shoulder. It was a very hot summer day. Parts and labor were covered under my extended warranty. The 4 banger must have been laughing his head off!
bbudz is offline
post #7 of 41 (permalink) Old 03-05-2008, 04:43 PM
Date registered: Mar 2008
Accelerator Cable Snapped CLK430 2001
Hi, I was driving in the fast lane during rush hour and going about 75 mph when my accelerator pedal all of a sudden went out and the car quickly started slowing. I eventually moved over to the right, where there was no shoulder and almost got hit by cars whizzing by from behind. I ended exiting the freeway at 2 mph, had to run an intersection and finally got my car into a gas station.
I thought this was the strangest thing and never heard of this before until I found your posts. Is this bad engineering or malfunctioning part? I had no choice but to tow it to the nearest Mercedes Benz dealership, they are charging me $450 parts and labor to replace the cable.... any advice?
yolo is offline
post #8 of 41 (permalink) Old 03-05-2008, 04:58 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 9 Post(s)
Any cable made to move is going to
wear.Help to prevent it and keep it smooth and new with a bit of graphite in a tube that you can get at any home improvement store.
ohlord
ohlord is offline
post #9 of 41 (permalink) Old 03-05-2008, 06:31 PM
Kajtek1's Avatar
Quoted: 1938 Post(s)
I guess since the cable operates only electronic potentiometer, the MB didn't worry about making it very strong. It didn't happen to me, but I had to deal with the $460 potentiometer, so I know that if that happens you could put something under the potentiometer stop ($100 bill multi-folded will work) and keeping high idle, while operating gear shifter might get you home.
Would have to test it, because those wheeled computers have mind on their own and mechanical logics too often don't work with them.
Kajtek1 is online now
post #10 of 41 (permalink) Old 03-05-2008, 07:00 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
It's not that it isn't strong enough, I'm sure.
Moving the pivot on the potentiometer will cause the end of the cable to flex, which will eventually fracture the cable. Graphite is probably a very good idea for that.
Matt L is offline
