Correct oil change procedure for 2017 or 2018 c63s - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-26-2017, 07:15 AM Thread Starter
Date registered: Oct 2008
Vehicle: 2018 C63S Coupe
Can anyone please publish the MB official engine oil change procedures?
I understand that in addition to the main plastic drain plug next to the oil filter (which is not reusable), there is another plug towards the front of the car that needs to be removed and drained as well?
Thanks
ahowell is offline
post #2 of 4 (permalink) Old 11-27-2017, 04:42 AM Thread Starter
No one has this info.?
ahowell is offline
post #3 of 4 (permalink) Old 11-28-2017, 05:23 AM
panzernacker's Avatar
Date registered: May 2016
Vehicle: 1989 W124 260E Saloon. M103 lump.
Quoted: 318 Post(s)
Dont play with drain plugs .Purchaee a oil transfer pump .Thats if you have a dipstick hole to put the pipe into .Some dont have the dipstick ,in that case you do need to use the drain plugs .
panzernacker is offline
post #4 of 4 (permalink) Old 11-28-2017, 06:15 AM Thread Starter
Thanks, but for some reason MB states that on only the AMG engines, oil must be drained from the bottom and not pumped out.
ahowell is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W205 C43 AMG, C63 AMG
