2016 c450 rough idle lacking power NEED HELP - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-05-2019, 11:52 PM Thread Starter
SilverC450's Avatar
Date registered: May 2019
2016 c450 amg 4matic 52,000 miles.
Getting codes P0171 & P017 and misfires in 4,5,6 and multiple misfires... car seems like it’s not getting any gas...
Bought the car and drove it back..at about 800 miles in I decided to throw in a bottle of gumout complete fuel system cleaner. then I would say about 3-400 miles after that the car lost power on the freeway and barely had enough to get if off the next exit.
The more gas you give it the more it wants to die.
Not sure if it’s a fuel filter or injectors or what... brought it to a shop call All Imports in Eagan, Minnesota to run diagnostics...they are closed on the weekend so I’m still waiting to hear back.
Any help or information will be appreciated greatly. This is my first financed car purchase and first Mercedes-benz.
SilverC450 is offline
post #2 of 3 (permalink) Old 05-13-2019, 01:38 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
My initial guess is a PCV valve failure. A way to check is to pull the oil dipstick while the engine is running and put your finger over it to see if you feel a vacuum.
What did the shop say?
n0alpha is offline
post #3 of 3 (permalink) Old 05-31-2019, 09:18 AM
89benz300se's Avatar
Date registered: Jul 2017
Vehicle: 1989 300se / 2016 C450 AMG
Quoted: 55 Post(s)
Getting codes P0171 & P017 and misfires in 4,5,6 and multiple misfires... car seems like itís not getting any gas...
Not sure if itís a fuel filter or injectors or what... brought it to a shop call All Imports in Eagan, Minnesota to run diagnostics...they are closed on the weekend so Iím still waiting to hear back.
Did you ever figure out what was wrong with the car?
89benz300se is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
B200 Turbo occasional rough idle almost always only after engine fully warmed up W245Wiggler W245 B-Class 7 06-22-2018 09:23 AM
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
Low power, rough idle, bad vib at low end of 4th ben.wilson W201 190-Class 9 01-07-2014 04:50 PM
Rough idle, no power BLUESTAR92 W140 S-Class 4 07-02-2008 10:20 PM
1995 sl500 rough idle power loss problem.. dpol1835 R129 SL-Class 8 10-28-2005 01:01 AM
