Where is fuse for fuel pump? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-05-2019, 01:09 PM Thread Starter
john.h.atkinson@gmail.com's Avatar
Date registered: May 2019
Vehicle: SLK 2001
I have a 2017 Jan Mercedes C200 petrol 3 door saloon car.
I need to know where the fuse is for the fuel pump, and which fuse it is.
Thank you for any info!
john.h.at[email protected] is offline
post #2 of 2 (permalink) Old 05-08-2019, 04:02 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 112 Post(s)
Is your car a W211 saloon or three door convertable or coupe . If so in the boot side wall left hand side you will see a square door in the side wall of the boot trim - remove the door and check out fuse 4.
This is a retro ride .
plinker17722 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
SLK32 Intercooler Pump Replacement 430 R170 SLK-Class 73 07-07-2014 12:33 PM
Replace bulb type foot pump window washer with electric pump (how to) frankflynn Vintage Mercedes-Benz 5 05-23-2013 02:11 PM
1984 190D 2.2 No oil getting to filter housing after new pump? neel2008 W201 190-Class 2 12-13-2012 04:06 PM
Successful DIY Notes for the list: Radiator, Fan Clutch, Temp Sensors, Fuel Pump ericgr R/C107 SL/SLC Class 8 02-18-2010 02:03 PM
380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 03:44 AM
