speakers wiring - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-15-2019, 06:16 AM Thread Starter
Date registered: Mar 2018
Vehicle: 2015
speakers wiring
If someone can help me about the speakers
which is the positive?the striped wire or the solid colour wire?
because on posts there is the striped wire is negative but when I m checking the speakers with a battery to identify the positive and negative ,the speaker goes down when using the striped as negative.
c220d205 is offline
post #2 of 3 (permalink) Old 04-16-2019, 02:38 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 767 Post(s)
Use a digital volt meter on the wires and it should tell you. Normally a - will come up before the voltage readout if polarity is reversed on the DVM leads.
mattml430 is online now
post #3 of 3 (permalink) Old 04-19-2019, 05:43 AM
Gallon's Avatar
Date registered: Apr 2010
Vehicle: 2015 S205 C200 AMG Premium Estate
Speaker wiring convention is as you say -ve is the striped wire but the main criteria is that all speakers on a system are wired the same way otherwise 1 speaker would be pulling in while the other is pushing out.
Gallon is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
R-class hitch install with Factory wiring harness radodrill W251 R-Class 110 05-21-2019 09:22 AM
Aftermarket audio in 1992 Becker equipped 500SL feedingtherat R129 SL-Class 9 10-06-2018 01:18 PM
Notes on Dome Light Wiring HalNineThousand R/C107 SL/SLC Class 0 06-15-2012 10:08 AM
[Merged] Stereo and Speakers Upgrade dave33333 W123 E,CE,D,CD,TD,TE Class 14 03-24-2012 08:26 AM
Change speakers on 420 SE JB420SE W126 S,SE,SEC,SEL,SD,SDL Class 6 03-31-2008 01:11 AM
