2017 C300 4Matic - vibration / pulsation (mostly felt in steering wheel)!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-26-2019, 04:43 AM Thread Starter
Date registered: Mar 2019
My C300 vibrates that is mostly felt in the steering wheel around 60mph. It becomes much more noticeable at 70+mph. Itís still under warranty and I have taken it to the local MB dealership and they have spent weeks trying to figure out what is causing the problem. They have replaced quite a few things, balanced and aligned the tires, tried to put different brand tires on (OME - Pirelli), among other things. Iíve driven the car with the shop foreman a few times and he agrees, there is definitely a vibration that pulses through the car and felt mostly in the steering wheel but can also be felt through the seats. After the dealership couldnít resolve the issue MB had their ďadvancedĒ guy from the region weigh in on it and had the mechanics do a few more things but this didnít do anything to resolve the issue. Now that they canít figure out what the issue is, MB is saying, ďit is operating as designedĒ and they have essentially washed their hands of my car.
Vindieselwalker is offline
post #2 of 3 (permalink) Old 03-26-2019, 08:43 AM
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2418 Post(s)
If you've hit a curb or a big pothole you could have bent something, possibly a control arm, less possibly a drive shaft. Not easy to spot visually. Only way to check a drive shaft, for example, is to put a dial gauge on a magnetic base against the shaft and see how much the needle moves back and forth as the shaft is rotated slowly by hand. Not unusual for a bona fide mechanical engineer, but probably a bit beyond the average grease-monkey. You could check for run-out on the brake rotor or its mounting on either side too in much the same way.
Even more unlikely is that you've somehow bend the entire frame.
My wife's 2015 C300 RWD certainly doesn't have any vibration and it's clearly BS that noticeable vibration is within limits (unless we're talking princess and the pea type stuff here).
"Semper In excretio, solum profundum variat" - unknown
They called me mad, and I called them mad, and damn them, they outvoted me" - Nathaniel Lee
IWantedaJag is online now
post #3 of 3 (permalink) Old 03-27-2019, 08:37 AM Thread Starter
My C300 vibrates that is mostly felt in the steering wheel around 60mph. It becomes much more noticeable at 70+mph. Itís still under warranty and I have taken it to the local MB dealership and they have spent weeks trying to figure out what is causing the problem. They have replaced quite a few things, balanced and aligned the tires, tried to put different brand tires on (OME - Pirelli), among other things. Sarkari Result Pnr Status Showbox Iíve driven the car with the shop foreman a few times and he agrees, there is definitely a vibration that pulses through the car and felt mostly in the steering wheel but can also be felt through the seats. After the dealership couldnít resolve the issue MB had their ďadvancedĒ guy from the region weigh in on it and had the mechanics do a few more things but this didnít do anything to resolve the issue. Now that they canít figure out what the issue is, MB is saying, ďit is operating as designedĒ and they have essentially washed their hands of my car.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
Single wire horn buttons - AMG steering wheel Fonzi R/C107 SL/SLC Class 7 11-02-2014 04:15 PM
Vibration in steering wheel Budd W163 M-Class 5 05-01-2010 01:50 PM
4x4 and lockers How it works on GW463? rey445588 G-Class 5 02-04-2008 11:10 AM
Weird Vibration in Steering Wheel-not wheel related andyv94 W140 S-Class 2 04-22-2007 12:56 PM
Wheel Vibration - balance and other things Skylaw The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-19-2005 09:14 AM
