Does standard sound system have dash subwoofer - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-14-2018, 02:46 AM Thread Starter
Date registered: May 2005
Vehicle: '91 300SL(sold) 2000 SL320 Edition '94 E220 T auto
Quoted: 30 Post(s)
My Father has a W205 with the burmeister system. I believe there is a subwoofer under or behind the dash. Works well.
I was considering buying an estate which is quite a basic car. Anyone know if there is still a subwoofer there? If not, anyone added it?
Thanks
silver50 is offline
post #2 of 5 (permalink) Old 12-04-2018, 11:11 AM
Traveler0980's Avatar
Date registered: Nov 2012
Vehicle: 2018 C-300 Convertible
Quoted: 14 Post(s)
You might want to talk to an audio specialist. They should be able to tell you what you have and how to get it to sound better. Shouldn't cost a cent to get their take on it.
Just my $0.2 worth
Traveler0980 is offline
post #3 of 5 (permalink) Old 12-16-2018, 10:01 AM
Date registered: May 2009
Vehicle: 1999 C280, 2015 C300
Quoted: 29 Post(s)
The dealer should be able to tell you if the basic system includes a subwoofer.
Georj is offline
post #4 of 5 (permalink) Old 12-16-2018, 02:20 PM
Gallon's Avatar
Date registered: Apr 2010
Vehicle: 2015 S205 C200 AMG Premium Estate
If you have the Audio 20 setup then the A20 system consists of (4) 4″ speakers in the doors and a single 6.5″ Frontbass subwoofer installed in an 8 enclosure located in front of the passenger footwell, all powered by the head unit manufactured by Mitsubishi.
Gallon is offline
post #5 of 5 (permalink) Old 12-20-2018, 02:34 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
Correct - base system does not have Front Center dash speaker - and does not have 2nd woofer - and does not have Tweeters in the front door triangles.
One "upgrade" is to add tweeters w/crossover to the triangles - to go farther than that (and you can go far) usually requires a plug-n-play add-on amp (like Fischer Match) - and then using upgraded digital amp to push upgraded speakers.
fabbrisd1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
