2015 C300 Oil change + torque specs - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-03-2018, 06:10 PM Thread Starter
Date registered: Feb 2018
Vehicle: 2015 C300 4Matic sports package
Hi, I cannot find in the Mercedes Owner Manual the torque specs for the drain plug.
I vaguely finds other mercedes specs online of 30 NM. Anyone knows the real torque spec from the service manual ?
I also see that the oil filter is 25 + 5 NM. What does that mean exactly ? 25 NM and then 5 NM ? so simply 30 NM ?
last question!
I saw that people are doing oil change by pumping out the oil now ? Is this a thing now ? Is this the new way Mercedes are doing oil changes ? What was wrong with draining oil trough the drain plug ?
Thanks!
Simon Guertin is offline
post #2 of 4 (permalink) Old 10-09-2018, 01:19 PM
Traveler0980's Avatar
Date registered: Nov 2012
Vehicle: 2018 C-300 Convertible
Quoted: 14 Post(s)
I think most of the people that are "pumpimg" out their oil are doing it as a DIY as this method avoids having to put the car on a lift and dropping the shield. If I'm doing it in my garage I "pump" it out. The dealer lifts the car, drops the shield and pulls the drain plug.
I also have an I/O boat where you have to pump the oil out as there is no access to the drain plug.
Can't help you with the torque specs, sorry.
Traveler0980 is offline
post #3 of 4 (permalink) Old 10-10-2018, 03:24 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 807 Post(s)
30nm is plenty for your drain plug and the filter seals on an o ring so 25 is standard for most Benz cartridge filter caps.
mattml430 is offline
post #4 of 4 (permalink) Old 10-10-2018, 03:39 AM
mattml430's Avatar
Quoted: 807 Post(s)
Originally Posted by mattml430 View Post
30nm is plenty for your drain plug and the filter seals on an o ring so 25 is standard for most Benz cartridge filter caps. I have only ever tightened them by hand. Never had one leak yet.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
