H7 LED kit that works with C300 W205 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-24-2018, 02:56 PM Thread Starter
Date registered: Apr 2017
My 2016 C300 was a Dealer Courtesy car. So I got an amazing deal on it at only 10K miles, it was pristine.
But it came with the standard halogen sealed headlight assemblies. I looked into a bunch of 'compatible' LED conversion kits - even ordered 2, but none of them fit so I returned them. The LED bulb assembly with heat sink & fan is to long and will not fit into the sealed headlight enclosure behind the access caps.
Took a fresh look around today and found these new Gen 3 LED bulbs that use a folded copper heat sink array instead of a fan. The folded array is made to be flowered out in all directions to carry away heat from the bulb. It also gives the bulb a much shallower draft when mounted in it's socket (see photo).
Anybody here have experience with these?
ID:	2429877   Click image for larger version
Name:	DSCN0436 Right.jpg
ID:	2429879   Click image for larger version
Name:	DSCN0435 Back 2.jpg
Tophat415 is offline
post #2 of 2 (permalink) Old 06-05-2018, 03:55 AM
Traveler0980's Avatar
Date registered: Nov 2012
Vehicle: 2018 C-300 Convertible
Quoted: 14 Post(s)
I had purchased a set from Carid for my 2009 CLK. I had to modify the clip that held the bulb in (another thread) but everything fit inside the head light housing. I loved the extra light I got.
Traveler0980 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
