2015 C300 issues - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-21-2018, 01:50 PM Thread Starter
Date registered: Jun 2016
Vehicle: 2011 E350
Quoted: 40 Post(s)
2015 C300 issues
So recently bought this car as a cpo with some manufacturers warranty left. Needless to say I love the car but I do have a laundry list Iím hoping i wonít get crucified for >_<. Anyone have some input on wording to help steer them better? Donít want to come off as being needy or annoying but I just want things to work right .
1. Scuff on wheel needs repaired
2. Alignment of tires and steering wheel (steering wheel is not straight to match tires when driving)
3. Rear passenger side door handle Led out (needs replaced)
4. Driver side door mirror has moisture in turn signal that wonít go away (replace?)
5. Whistling/Ticking noise in engine on cold starT
6. Check TSB/log customer concern that vehicle falls into production time frame for faulty Wrist Pins in engine according to Daimler (LI72.10-P-062500 or LI03-10P060916) (NHTSA ID #10058545)
- Summary: Xentry: Due to unfavorable tolerance of Piston Wrist pin, Resulting in knocking, clattering/rattling noises, causing an enlarge end floating connecting rod in piston, from crank assembly of engine when cold (defective parts are in engines made before April 20, 2015)
7. Rattling on Passenger side of vehicle thinking passenger head rest, currently un adjustable wonít go up or down. Stuck/broken piece in seat maybe?
8. Irregular shifting gears 4 & 5 on upshift and down. Not smooth at all, almost like transmission lags on these gears.
9. Driver side headlight on low beam is noticeable fallen lower than right when driving at night, can it be adjusted up?
10. Wind Noise from driver and passenger windows is excessive especially when crosswinds hit car. Almost sounds like windows arenít sealing correctly or rolled up all the way.
- GI72.10-P-061763
These are the main issues I have noticed since purchasing the vehicle 1/15/18. Please do your best to address them. I really appreciate everyoneís hard work and look forward to continuing to do business with mbofmc.
Sincerely,
Nick Riedel
njriedel25 is offline
post #2 of 3 (permalink) Old 01-22-2018, 06:52 AM
Traveler0980's Avatar
Date registered: Nov 2012
Vehicle: 2018 C-300 Convertible
Quoted: 14 Post(s)
Sounds like something I'd write if I had those problems. I wouldn't worry about hurting the dealers feelings, after all it is your money.
Just my $.02 worth
Traveler0980 is offline
post #3 of 3 (permalink) Old 03-03-2018, 10:02 PM
Date registered: May 2009
Vehicle: 1999 C280, 2015 C300
Quoted: 31 Post(s)
From what I have found out, wind noise is very common on 2015 C300. If you REALLY COMPLAIN I have heard that MB will try to fix the problem,
I have a 2015 C300 and I am very disappointed. It is in no way a MB brand luxury car. It drives like a cheap Korean sports car.
I also have a 1999 C280 with almost 200K miles, and it drives like a charm. It is not as fast, but it is a true luxury car.
My 2015 C300 has only 11,000 miles and full factory warranty, I am going to sell it asap.
If interested contact me.
Georj is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
