Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   W205 C-Class (https://www.benzworld.org/forums/w205-c-class/)
-   -   Mercedes C250e W205 Stalk Steering Column dont work !PLEASE HELP! (https://www.benzworld.org/forums/w205-c-class/2925082-mercedes-c250e-w205-stalk-steering-column.html)
grzegorzmerc 12-17-2017 03:24 PM
1 Attachment(s)
I have Mercedes Benz S205 C350e It has problems with steering wheel. All buttons don't work, so I can not change the gears only P mode and the car can not be moved all fuses are ok,I fit new stalk and nothing changed.PLEASE HELP !!
Any idea what is the problem? Thanks
ashleyashley 02-22-2018 10:54 AM
hello did you fix this? i have the same issue
radzisz1997 05-15-2018 04:23 AM
Did someone fix this?
ashleyashley 05-15-2018 11:51 AM
Hey so there can be only a few things that can do this
1 check the fuse there is a fuse for the column potentially
2 was th car in an accident if so check th two small cables that come off the steering rack, there should be a minus a plus and two small canbus cables, if the small ones are cut the steering wheel won't function and you won't be able to select gears
3 make sure you eis has not ve tampered with if the eis the unit you put your key in to it's a black box behind the key hole. If there was a can blocker in there or something foreign that can also kill ththe steering wheel
4 lastly check all canbus flexray diagrams
speedfoxsf03 05-17-2018 08:07 AM
hello, in my country we have a recall clearance letter for this issue. So last month I've leave my car for change the steering column. I hope it can help you.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
