Permanently disable miserable stop/start? - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 05-03-2018, 06:23 PM
Date registered: Jul 2017
Vehicle: 2018 W463 G550
I Just came across to this ebay link:
https://www.ebay.com/itm/MERCEDES-ca...-/252811119026
TEE287 is offline
post #12 of 19 (permalink) Old 05-24-2018, 02:10 PM Thread Starter
Date registered: Apr 2017
They must've added it for 2018. Can't find it under 'Settings' on my 2016. You'd think it would be a software upgrade for all W205's
Tophat415 is offline
post #13 of 19 (permalink) Old 05-24-2018, 02:27 PM Thread Starter
You're my hero.
I sent a note to the seller asking if stop/start remains disabled even if you change driving modes (ex from default 'Comfort' to 'Sport')
post #14 of 19 (permalink) Old 08-28-2018, 12:14 PM
MB-SV's Avatar
Date registered: Nov 2007
Vehicle: 2013 C250
Quoted: 83 Post(s)
^ So what happened?
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2016 Ford Mustang GT Premium (+Ford Performance by Borla-Touring exhaust, etc.) white/black
MB-SV is offline
post #15 of 19 (permalink) Old 08-29-2018, 04:00 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 742 Post(s)
Select driving modes via your main screen using the (vehicle) button on the centre console.
Then select (individual)
Set up your most commonly used driving mode and turn off the stop start at the same time. Then select individual for your main mode of driving. It will come up as an I* in the driving mode box on the dash.
mattml430 is online now
post #16 of 19 (permalink) Old 09-07-2018, 07:28 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
Vladimir's module is righteous - he's a bright and capable guy - message him your VIN# thru the eBay listing and ask him what features he can program for you.
On his ECO module - if you set ECO to off then you turn off your MB - next time you start your MB ECO stays off thru all profiles - if set ECO on then turn off your MB - the ECO is ON thru all profiles - smart and EZ.
Follow his install instruction OBD module plugs for changing your programming - once programming is changed module comes out - unless you want to reprogram back to stock/default - once used - works ONLY for the MB you have paired it with...
fabbrisd1 is offline
post #17 of 19 (permalink) Old 09-10-2018, 03:34 AM
Date registered: Feb 2014
Vehicle: benzw205
Quoted: 19 Post(s)
Originally Posted by NYYYCE&EEEEZY View Post
The subject of M-B's ECO Start/Stop has been the subject of many discussions on various model forums here as well as other sites with M-B forums.
From everything I've read up to now, there is no way to permanently disable this feature. It's M-B's way of improving mileage statistics, and even the dealers won't agree to disable it.
I considered not buying my 2014 212 when I learned of the feature, but fortunately I didn't let that influence the ultimate decision. Instead, each time I get behind the wheel, I just start the engine, fasten the seat belt, switch off the ECO button, and I'm on my way. No stopping/starting at every red light, stop signs while you wait for traffic to clear, stop-and-go traffic, etc.
Not the solution you're looking for perhaps, but it works for me, and I don't have to worry about whether the frequent stopping/starting of the engine might be harmful over the long term.
This is the solution that should work for everybody. And it works for me when I was one of the first to complain about this start/stop crap.
benzw205 is offline
post #18 of 19 (permalink) Old 12-04-2018, 11:50 AM
Date registered: Oct 2008
Vehicle: 2018 C300 (W205)
Quoted: 2 Post(s)
Yeah, and I think there's also an ODB module to enable Apple Carplay on 2018's.
a_ronaghi is offline
post #19 of 19 (permalink) Old 12-08-2018, 06:58 AM
Date registered: Dec 2018
Vehicle: 2012 C-Cass coupe 180 cgi and 2015 SLK 200 with tuning box.
Stop start delete free.
Originally Posted by Tophat415 View Post
Anyone know a hack to permanently disable the miserable auto stop/start? Not just for one trip - but forever? Let me know!
5 minute job, go to main battery under bonnet/hood and remove cover, attached to the negative (black) battery terminal you will see a box with 2 small wires, this is the negative rail battery sensor, disconnect it, that`s it. Your alternator will now revert from smart to standard, it will charge from 13.8 to 14.2 volts and fully charge your battery not just 80% as before. There is no EML, stop start is still there but never goes green, everything works as normal other than brake hold which you no longer have. With stop start no longer working you can replace main battery with any sealed lead acid battery. This hack is no good if you have cylinder deactivation as you will loose this along with brake hold, if you want to go back to standard just plug sensor back in, enjoy.
Robuk22 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W205 C-Class
