2012 C-63 engine oil notice - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-15-2016, 12:58 PM Thread Starter
Date registered: Jul 2016
Quoted: 2 Post(s)
recently purchased a 2012 C63 and have put maybe 5K on it since taking ownership. coming into work tis morning, received an in dash warning asking me to check oil level at next fill-up! Is there an issue here that I should be aware of? just don't seem normal !
JPCouet is offline
post #2 of 4 (permalink) Old 07-15-2016, 06:17 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1901 Post(s)
Welcome.
Scroll down the forum index to your chassis: W204 C63 AMG. I copied your thread there.
There is also a non AMG W204 forum.
Please click 'User CP' on the top toolbar to complete your profile with car mod and location.
Daimler Benz frequently makes same chassis but differently equipped cars for different parts of the world, so on an international forum, location can be important to get the correct advice.
Reading the stickies on top helps to navigate.
Cheers
Teutone is offline
post #3 of 4 (permalink) Old 07-24-2016, 07:44 PM
Date registered: Jul 2008
Quoted: 25 Post(s)
Welcome to the forums. Your car is telling you to check the oil level because you are either burning through it or it is leaking. Check the PCV at the back of the head, the valve cover gaskets, the seals near the cam sensors, and the drain plug. I have a PCV kit available on my website if needed. Treat the low oil message seriously and consider checking your oil level more often.
--Kyle
https://www.fcpeuro.com/products/mer...s-1560100370kt
FCP Euro is offline
post #4 of 4 (permalink) Old 09-29-2016, 10:01 PM
Date registered: Jul 2009
Vehicle: 2001 SLK320 ex Japan.
Quoted: 21 Post(s)
--Kyle
I read a spec somewhere about oil consumption but cannot recall where.
It will use some so check it say 1500 km after a change and then randomly so you can see when it needs a top up and go from there.
Alex3 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W204 C63 AMG
