W204 C200 CDI Second Battery for Remote Monitoring - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-16-2013, 03:38 AM Thread Starter
Date registered: Apr 2013
Hi I would like to install a second battery, probably in the boot, to support a remote monitoring facility, has anybody done this? Or is it perhaps available from Mercedes as an option? I just need the battery, (and charging circuit), as I will be installing my own monitoring system. The boot appears to have space and brackets where one might be fitted?
brucedale is offline
post #2 of 2 (permalink) Old 05-17-2013, 03:33 PM
The auxiliary battery for cars fitted with the stop start system is fitted in the boot. There is also a SAM [ ELECTRONICS UNIT] in the boot which should have a direct 12volts supply. Having said that the electronics on these cars is so complex nowadays you really need to get a vehicle electrician who knows these cars to advise you ----to avoid blowing something expensive up.
grober is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W204 C63 AMG
