"Without changing gear consult workshop" - u010387 error code - Mercedes-Benz Forum
LinkBack Thread Tools
Old 05-18-2019, 10:20 AM Thread Starter
it0022's Avatar
Date registered: May 2019
Vehicle: 2014 C-Class W204
Hi
My mercedes C class w204, 2014 has a red message saying "without changing gear consult workshop". The gears will not change and now stuck in P.
Mechanic said Transmission is fine as it "clicks" and it is an electrical fault. It all started when (in trying to fix a left window airbag warning) the connector under the passenger seat was disconnected and the ignition turned on. Put the connectors back but still giving this issue.
Can not be cleared with several good diagnostic machines. Shows a u010387 error code. "Communication with the electronic selector level module has a malfunction". It seems to me there was some short circuit or loss of communication in messing with the connector under the passenger seat and turing the car on while disconnected. I've checked all the fuse etc
Any ideas how to reset it or get it to work? Mechanics have no clue all saying different things.
Thanks
it0022 is offline
Old 05-29-2019, 07:56 AM Thread Starter
it0022's Avatar
Turns out it was a fuse problem on passenger side
it0022 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Trouble changing gear Smokin_hole V-Class 5 03-11-2008 06:42 AM
Changing Gear Knob P18TRG R171 SLK-Class 8 08-07-2005 06:49 PM
Low frequency vibration at start and changing gear. BenZ190D W201 190-Class 11 07-01-2004 01:18 PM
What are everybody's thoughts on changing rear differential gear ratios? Dave OH R170 SLK-Class 9 11-19-2002 06:02 AM
According to Edmund's review of SLK32... Albert (Vancouver) R170 SLK-Class 12 07-20-2001 10:21 PM
