Battery issue - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-06-2019, 02:03 PM Thread Starter
MrPid's Avatar
Date registered: May 2011
Vehicle: 2005 SLK55 AMG
Quoted: 13 Post(s)
Battery issue
Hello all. I have a 2010 C300 4matic with about 120K km on it. This past week I traveled to Oregon . I drove to the ferry line up and waited , listening to some MP3 I had on DVD. Occasionally the radio would turn off. I'd turn the ignition back on and start it all up again. Then it would turn off again and as time went on it would turn off sooner. The ferry finally started to load and the car would not start!!! I needed a jump to get on the ferry and then at the other end to get off. I now understand why the radio was turning off but there was no dashboard alarm warning of a low battery. That just doesn't make any sense at all. This car has alarms for everything else but not a low battery. I made it to the nearest Autozone and got a new premium battery. The car still had the original Mercedes battery, not bad, 9 years.
2010 C300 4MATIC , sharing with 2006 SLK55 AMG/auto and 2007 DUC M800
MrPid is offline
post #2 of 4 (permalink) Old 05-09-2019, 01:19 PM
Date registered: Aug 2008
Vehicle: 2003 clk 500
It runs good after new battery?
fufuflavor is offline
post #3 of 4 (permalink) Old 05-09-2019, 01:21 PM Thread Starter
MrPid's Avatar
Quoted: 13 Post(s)
Runs fine, no issues
MrPid is offline
post #4 of 4 (permalink) Old 05-18-2019, 11:22 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
Glad your car is running smoothly again, and 9 years is very respectable for a battery. Most likely because you’re in the cooler Pacific Northwest climate.
Here in Texas the heat shortens the life of batteries and I have had my local AutoZone tell me that they expect a battery to last about 5 years but depending on the quality of the battery some only last 3 years.
n0alpha is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
W221 2007 S600 / S550 group size V4 battery mystery solved! wampa007 W221 S-Class 8 07-13-2019 07:59 PM
W166 2013 ML350 4Matic Battery Change Instructions isdljbh W166 M-Class / GLE-Class 1 02-10-2018 09:59 AM
Battery Drain? Slow/Rough Start Issues AndyK150 W212 E-Class 6 02-02-2017 04:37 PM
battery issue, trickle charge rear battery ?? Alex Taha R230 SL-Class 5 05-02-2016 12:19 PM
Workaround for Battery drain issue on 2001 c240 gangsta101 W203 C-Class 7 01-10-2016 11:03 AM
