esl replacement. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-09-2019, 10:50 AM Thread Starter
Date registered: Apr 2019
Vehicle: 2007 c220 sport
esl replacement.
Hi Guys.
I am hoping you can help me please.
I had the esl lock in position and would not release so I took the steering column out and undid the splined knuckle joint in the footwell to take it out of the car.
I had the esl repaired and when I have installed the steering column in the car I cannot get the steering column spline into the knuckle joint spline in the footwell, I have removed the bolt from the knuckle joint.
Cheers.
Ian.
irbref is offline
post #2 of 2 (permalink) Old 04-11-2019, 09:39 AM Thread Starter
Hi Guys.
I have sorted the problem and have wrote below how I fixed it in case any one else has the same problem.
I bought a second hand steering column and lower knuckle joint to see how they go together and they only go together one way.
There are 3 grooves in the column and knuckle joint and they have to match, next time I will mark anything I take off.
irbref is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
"Airmatic Visit Workshop" after strut's replacement Nachogy W220 S-Class 16 12-31-2017 10:47 AM
DIY 1999 S320 Mercedes coolant thermostat replacement with picturess chickenfriend W140 S-Class 2 02-16-2013 04:30 PM
Spark Plug Replacement Interval - and Replacement Plug pengineer W126 S,SE,SEC,SEL,SD,SDL Class 2 03-03-2012 01:52 PM
DIY Procedures (Updated 03.18.08) JOE55 W210 E-Class 0 07-05-2007 11:48 AM
My thanks to my local MB dealer on honoring MB replacement parts fabbrisd W126 S,SE,SEC,SEL,SD,SDL Class 7 07-09-2006 09:08 AM
