Head Lights Low beam lamp - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-15-2011, 06:35 AM Thread Starter
Date registered: Jan 2011
Vehicle: C300-2009
Dear Experts,
After i got the "Check Right Low Beam" on display, I found my right low beam not working. I have ordered pair of low beam lamps from genuinemercedesparts. com. Is there anyway i can make sure they are OEM/at least compatible before i go ahead and change the lamp??? any part number or something like that??
I appreciate your help.
Thanks.
oldhook is offline
post #2 of 10 (permalink) Old 08-15-2011, 09:39 AM
Ron Jr's Avatar
Date registered: Mar 2008
Vehicle: 2013 C300 Sport Darth V 3.0
If you have halogens they are just regular H7 bulbs.
"A Brabus Maybach," he said, as she turned her head in time to see him give the wheel a little pat. "The firm of Brabus extensively tweaks the product of Maybach, to produce one of these."
"Darth my ride?"
From chapter 17 of Spook Country by William Gibson
Ron Jr is offline
post #3 of 10 (permalink) Old 08-15-2011, 10:06 AM Thread Starter
Vehicle: C300-2009
Thanks Ron. I think Mine are stock which are Halogens..
oldhook is offline
post #4 of 10 (permalink) Old 08-15-2011, 03:24 PM
Ron Jr's Avatar
Not a problem.
"Darth my ride?"
Ron Jr is offline
post #5 of 10 (permalink) Old 08-15-2011, 07:44 PM
Date registered: Mar 2011
Vehicle: 2011 C300 Sport, P1, MM, Wood, HFS, Palladium Silver
Someones knows if there is a LED H7 bulb, bright enough for headlight not jkust for fog light? Most reviews say LED headlight is not bright enough but OK to use as fog light.
C300HE is offline
post #6 of 10 (permalink) Old 08-16-2011, 09:18 AM
Ron Jr's Avatar
Not available on the market as far as I know. Most likely in development.
"Darth my ride?"
Ron Jr is offline
post #7 of 10 (permalink) Old 08-16-2011, 11:02 AM
I know Toyota Pruis has LED headlight (not fog light) starting 2010, on its highest version (level V or so?). I have its 2011 brochure but I don't know what size it is.
C300HE is offline
post #8 of 10 (permalink) Old 08-16-2011, 02:26 PM
AZN_C300's Avatar
Date registered: Apr 2008
Vehicle: Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
it really has less to do with the bulb than it does with the housing to properly reflect LED type lighting without scatter.
AZN_C300 is offline
post #9 of 10 (permalink) Old 08-16-2011, 03:04 PM
But what about lumen? That is the most important specification.
C300HE is offline
post #10 of 10 (permalink) Old 08-17-2011, 08:19 AM
AZN_C300's Avatar
There are LEDs that can achieve the same lumen output as halogen, but those are pricey with complicated heat dispersal, especially in confined spaces. That's why it's suggested to just go HID for lighting that needs to project out.
AZN_C300 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Replace 07 low beam head lamp troybarwick W164 M-Class 10 12-13-2010 09:04 AM
New DUAL HID Projector head lamp LOW BEAM out ?! danger450 R170 SLK-Class 5 09-16-2010 08:42 AM
Head lights low beam and park lights and tail lights kojo W202 C-Class 5 09-14-2010 06:03 PM
Projector Beam Head lamp discussion. Square Cabs yarr Unimog 15 06-08-2009 10:07 PM
Main Beam lamp, cluster lights and Head light failure. Is this likely a related problem? isobars W126 S,SE,SEC,SEL,SD,SDL Class 4 03-05-2006 08:37 AM
