Smart Key Repalcement shell - it's so easy - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 03-31-2010, 04:37 AM Thread Starter
Date registered: Mar 2010
Vehicle: C Class Estate 270, ML 320 (previous;A-Class, C-Class 200k, CLK 320, SLK 350)
Smile Smart Key Replacement shell - it's so easy
Problem was the membrane on the key for my W203 was breaking up but its the same key on many MB models.
£200 for a new MB one or DIY was the dilemma.
Tried my luck and bought a virtually new fob from eBay for £11.00 including postage.
Decided to swap the electronics from duff key to replacement which took exactly 30 seconds and I have not done this before.
All you need is a lipped small screwdriver as found in those "sets of small tools" many DIY stores for working on mobile phones etc.
Process is take out the battery section of the key.
Push in your lipped screw driver as shown in the picture and using only moderate pressure to push back the white tab on the white plastic locking spacer just pull and out comes the whole PCB.
Do the same on your original key and push into replacement key and battery and off you go.
No programming, no expensive trip to a MB dealer.
Pictures explain it visually.
ID:	299546   Click image for larger version
ID:	299547   Click image for larger version
ID:	299548   Click image for larger version
PhilAllam is offline
post #2 of 13 (permalink) Old 03-31-2010, 08:12 AM
Diesel Benz's Avatar
Quoted: 58 Post(s)
Note that the chrome key on a W204 is different (not a lot though).
Diesel Benz is offline
post #3 of 13 (permalink) Old 12-20-2010, 08:01 AM
Date registered: Nov 2009
Reviving an old thread....
So how different are the instructions for the chromed key?
I'm trying to do the same for a W164 key that has a cracked shell. The picture below found online indicates it can be done...but it doesn't have the same white tab mentioned above. Help is appreciated.
spielnicht is offline
post #4 of 13 (permalink) Old 12-20-2010, 09:02 AM Thread Starter
shell replacement
hi,
looking at the picture I would pull out the battery using the sliding tab.
Then gentle pull on the printed circuit board using some tweezers or thin long nose pliers using the edge of the board to grip on.
If it does not pull out easy the board will be held and located on some plastics lugs on the shell and you have to push in (gently) a fine screwdriver to flex the board off the lugs whilst pulling with the tweezers/pliers.
Just go about it gently but a second pair of hands or a small clamp/vise to hold the shell is a good starting point.
Putting it back together is easy as it just a push fit after lining up the PCB.
post #5 of 13 (permalink) Old 12-20-2010, 12:06 PM
Quoted: 58 Post(s)
Originally Posted by PhilAllam View Post
hi,
Nice to see the OP of this thread coming back. I agree completely with the above. The main difference with the older black key and the chrome key is that the battery is released by pushing the lever to a different direction but this is explained in the car manual too.
Perhaps spielnicht got confused when the photo showed the "wrong side" of the circuit board.
post #6 of 13 (permalink) Old 12-21-2010, 04:46 AM
Thanks guys! Yea, the chrome version turned out to be the same procedure. There was a white tab as well, just not shown in the pic above. I just used small needle nose pliers and PCB came out effortlessly and now I have a new [already programmed] key :-)
Thanks again for the quick reply.
post #7 of 13 (permalink) Old 01-14-2011, 06:06 AM
Schweinhund's Avatar
Date registered: May 2010
Vehicle: 2000 W210 E55 AMG, Silver/Black - Stock
Quoted: 2 Post(s)
Does anyone know which chip is the flash chip?
Schweinhund is offline
post #8 of 13 (permalink) Old 01-21-2011, 09:52 AM
Date registered: Aug 2009
Vehicle: 2009 C300 4matic (White on black, sport, P1)
I have the w204 key that came with my car. The oval with the soft buttons. But the buttons on my main key has cracked and look like crap. Does anyone know if it is possible to purchase a new shell and swap the guts. I saw how you got the guts out of the old style w203 key, but not how you opened up the w204 key...
Also, I was wondering if it is possible to upgrade to the new 2010/2011 key design where it is more square and bulky and has actual hard buttons (to stop the cracking that mine has encountered).
Any advise would be appreciated!
jctevere is offline
post #9 of 13 (permalink) Old 01-21-2011, 03:50 PM
Date registered: Dec 2008
Vehicle: 2007 W204 C280/C300
Same question for me. Thanks!
albert101 is offline
post #10 of 13 (permalink) Old 02-10-2011, 07:52 AM
Date registered: Feb 2011
cracked key shell for wdd 204
samke problem for me too;-(
daniel ng is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Replacement Key Shell Available? warren032 W210 E-Class 18 08-26-2015 06:50 PM
Old Smart key Guts into new Chrome Smart Key??? lts70 General Mercedes-Benz 10 11-22-2012 04:21 PM
Wet Smart Key ... not so smart Joma W211 E-Class 18 10-20-2011 08:13 AM
Want to get chrome smart key, will just any smart key work? timmynabenz C209/A209 CLK-Class 1 12-06-2008 07:49 AM
Remote Key Shell parts zeeksson2 W163 M-Class 0 09-03-2008 06:18 PM
