c32 amg - p0410 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-24-2017, 09:00 AM Thread Starter
Date registered: Jul 2016
Vehicle: 2003 S500, 2002 C32 AMG
Exclamation c32 amg - p0410
Hi guys, I'm having codes p0410 (secondary air injection system) and sometimes having p0444 (evaporative emission system purge control valve circuit open). I read about the p0410 being most likely the air pump and relay, so I changed that out of a parts car I had. now the code comes back at random, and instead of coming on a startup, it does it at random after being driven. went on a 2 hour trip in the car and the code did not come on. then the next day went to the store and as soon as I parked, the code came back. I didn't think it could be the pump and relay, as I have read these only come on for about 30 to 40 seconds within the startup of the car. Any thoughts on this? thanks in advance
w220dad is offline
post #2 of 3 (permalink) Old 03-05-2018, 08:09 PM
Date registered: Apr 2017
Quoted: 2 Post(s)
Pull the egrís, strip them... clean them, new gaskets, hoses. Should look like new, like the old girl deserves. Everything should be fine then. O2 sensor just looking for a change when egr is called for.
Brian K is offline
post #3 of 3 (permalink) Old 05-12-2018, 09:36 AM Thread Starter
Where might the EGR valve(s) be located?
Still having the same issue to this day, but have found out more. The inside of the hoses and tubes going from the secondary air pump to the two valve in front of the surge tanks have small amounts of condensation in them. Replaced all of these off of another C32 (which had completely dry inside and looked brand new). Cleared the CEL and drove for a few days until the CEL came back on with the same code, the P0410 secondary air injection system. Looked inside the secondary air injection hose and tube and also the two valves I replaced in front of the surge tanks, and they all had condensation build-up on them. I'm assuming this is also not normal and may have something to do with the P0410 code. Is there some sort of air check valve or exhaust gas valve that would allow condensation into these air tubes? Any help is appreciated as I still have the same problem months later
w220dad is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
