Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   W203 C32 AMG, C55 AMG (https://www.benzworld.org/forums/w203-c32-amg-c55-amg/)
-   -   Problem transmission mercedes 722.6 (https://www.benzworld.org/forums/w203-c32-amg-c55-amg/2887361-problem-transmission-mercedes-722-6-a.html)
Radu Mihai Tifachi 09-30-2017 06:22 AM
Hello.
I have a problem with a transmission 722.6 mercedes.
I want to ask if you have any idea what the problem is and what I need to fix it:
-the diagnosis gives me the next error The P2500 gearbox has a non-transmitted transmission ratio, P2502
P2502 (implausible gear or transmission slipping)
As a description: The car goes well without shuffling. but when I kick it down or I accelerate it hard I think at the speed shift of 2-3; the car accelerates, increasing engine speeds up to 6-7000 rpm, but the car stays in place (going from inertia) as if it accelerated in neutral; after I stop accelerating and slowing down, go in speed with a shock.
I'm waiting for your answer, thank you very much.
Benzyle 10-05-2017 04:48 AM
Service the transmission. Put new fluid,new filter,new gasket,new harness connector.
Drive it smoothly.
waveterrorist 01-29-2018 04:49 PM
before servicing
do a TCU reset.
not saying it will help but it can't hurt.
if you drop the valve body put in the sonnax overlap kit and new torque solenoiid
insame1 02-01-2018 12:21 PM
Dollars to doughnuts you have a bad conductor plate. The output speed sensors crack on these all the time. Do yourself a favor and get a star scan first. Could be something as small as a bad battery
TheActor 02-01-2018 12:30 PM
Originally Posted by Radu Mihai Tifachi (Post 16607369)
Hello.
OP is right these transmission don't go bad but the plastic parts do 99.9% of the time. I had the same problem would be driving on the highway then thunk the car jump started revving not moving cracked speed sensor in TCU. It was very nerve racking at first but only takes about 4 hours to do taking your time.
insame1 02-01-2018 12:51 PM
Just FYI OP is original poster. that is who you quoted.
TheActor 02-01-2018 12:54 PM
i quoted him but was referring to you that's why i put OP in it.
insame1 02-02-2018 06:27 AM
Still dont quite understand
this reads that the original poster was correct.
Now if you wrote. "OP, insame1 is right" this would make senses.
TheActor 02-02-2018 03:39 PM
If i quoted him why would i need to even say OP?
edfreeman 02-02-2018 05:33 PM
Back on topic, guys. Thanks.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
