2005 CLK 550 charging issues - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-12-2017, 09:25 AM Thread Starter
Date registered: Mar 2010
Vehicle: 1997 C230 184K
Quoted: 4 Post(s)
This is for a less tech savvy friend who has a 2005 CLK 70k miles. He has garaged it over the New England winters but never put a trickle charger on it, last year it began to not start he put a new battery in it and put it away for the winter. I looked at it yesterday it had no CEL codes but my meter isnt for newer cars. It will not start with a jump until the battery has charged enough to run it but i didnt start yesterday and only runs for a little while. Sounds to me like the alternator and charging circuit I looked at fuses and smelled relays but the alt is buried in the engine. The nearest MB Stealer is 45 minutes by flatbed but I am going to suggest he have theone guy that will work on it put it up on the lift and put in an alt and check the wiring ect I cant do it in my driveway like my 97. Ant thoughts as to where I could look without lifting it? Ty
MartySzy1 is offline
post #2 of 2 (permalink) Old 08-11-2017, 10:09 PM
Date registered: Aug 2015
Vehicle: 2006 C55 AMG
volt test
test your battery voltage a good battery is 12.7 volts or higher when new and with the car off
test battery volt when engine running it should be 14.2 or higher 14.4 V
then test with all electrical parts on like head lights and fan this will load test alternator should hold 14.2 volts
duke749 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
